Anachronistic Anomaly
What is this peice I found in my door?
I found this rattling around in my driver's side door. Everything is still working properly, but I imagine this might be essential to the operation of something. edit: It's metal.
Anyone know what this is? (Sorry about the pic, all I had was my cell phone.)
IG@ the_derek_whitacre Last edited by lfot; 12-30-2008 at 02:44 PM.. |
Not sure exactly what it is, but i had same piece laying in my door too. I think there was an earlier post, maybe even Wayne's 959 with same problem and I think it was part of power windows, something to do with limit of travel.
Of course I could be totally wrong as it's been a long time since i read the thread. Anyway, my windows seems to be working fine without it !!!
Matt Kellett 87 Carrera Coupe - Marine Blue 60 MGA - Chariot Red 66 Jaguar MKII - Sherwood Green 09 VW GTI - Candy White |
I am going to guess that it attaches to your window at the base where it sits in the rail that makes it go up and down. It probably shrunk with time and heat and got loose.
Just a guess. |
Wer bremst verliert
It looks like the door latch lever retaining clip. AFAIK it was plastic in most cars and all the ones I've seen but it looks very similar to that part. If it is what I think it might be, it keeps the door release rod in the door release lever...
Like This?
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
IG@ the_derek_whitacre |
Window regulator Pivot (slotted end)........
That metal piece is the broken section of a window regulator pivot mechanism. I had one piece like that when mine broke. The window regulator control spring sits right on it. HTH. Tony |
Thanks Tony,
So what does that mean? Am I looking at pending disaster?
Tony is spot on. Here's a link to a thread from several years ago (which also contains other links). It's been several years since I remove that "annoying rattle piece", and I haven't had any issues since.
Can someone identify this window/door part? |
"when the window is up all the way, there is a slight rattle coming from the door. If I nudge it down just a tick (still sealed), the rattle goes away."
Mine has been like that since I bought it.
Jim 911 Mint Green "RSC" #mintgrun 911 Gentlemen's Rallye 85 Carrera GP White 2012 C63 AMG Mars Red |
I read both threads, and I see that that if everything works, its fine(been fixed). Then what is the rattle sound when the window is at max height that goes away when a "tick" down with power windows?
And why did I misspell piece in my original post?
I wasn't going to call you out for spelling. Glad you did. ha
Regis turd ab user
It appears to be what is left of a pivot bolt, could have been replaced by previous owner and never fished out of the bottom of the door?
Band.
You're in the "What is this thing in my door" club!
It's a "pivot spring retainer." Inside the door there's a big "clock spring" looking thing for the power windows. That part is mounted to the door sheet metal; it sits in the center of the spring and holds the spring tension. The original design didn't work out very well, and it's a frequent point of failure. Jim is right, apparently many times if a tech fixes it and can't find the old one that fell off, it stays in the door and you find it years later. here you go: http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_INTpnl_pg2.htm#item10
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Czar of C.R.A.P.
Had it also..... It must be bad luck to remove it from door so it just gets left in there. I would put it back in and stick it in place with some of the black goo that holds the wires out of the way.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Insert Tag Line HERE.....
We replace them all the time. It installs into the regulator and the new part must be welded on. Its basically there to keep tension on the window so it wont 'slide down' and if yours is broken, the big spring will come apart sooner or later.
Often this piece is the first clue your Porsche is in need of major work. Wouldn't surprise me to find you needed valve guides, Time Certs in the case, maybe line boring and blue printing or possibly a new transmission.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
You can get an appropriately sized axle or shoulder bolt at the hardware store, and in <30 minutes of work with a cutoff wheel, manufacture a close facsimile. Then just tack it into your window regulator with a welder. After removing the regulator, it will seem like a breeze ...
![]() If your window goes up and down at normal speed, the pivot spring probably caught on something else and is still doing most of its job.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
. In my case, 4-5 years after fishing that piece out of my door bottom, my window still work just fine. I have to assume the PO "fixed" the regulator, but I can't seem to locate the 3.6 so I think it was a hack job repair...
