stock radio problems
The radio (and CD player, etc.) in my 95 cab often plays on only the right channel, but will sometimes play on both.
Idea? Thanks. |
Remove the radio & swap speaker leads. If the problem stays on the same side, then the problem is in wiring and/or speakers. If the problem switches sides, then the radio is the problem. Check all connects for tight
Tom |
| All times are GMT -8. The time now is 12:49 PM. |
