-   -   Mad about steering problems (http://forums.pelicanparts.com/porsche-911-technical-forum/449002-mad-about-steering-problems.html)
Bart_dood 12-31-2008 04:00 PM
So long story short, about 4-5 weeks ago I bought the turbo tie rod kit from our hosts and put it on.
I have been doing some other jobs on the car in the last couple of days and I just checked my steering with the wife, with the car sat stationary with my wife moving the steering back and forth about 15-20 degrees there is a clear knocking/clunking, I felt down to the steering components and it feels like the inner tie rod ball joints are worn already!
When I first did the car with the new kit I tried the same thing and no clunking etc.
I've only done about 600 miles since doing the kit and I pretty bummed its worn already, I have completely stock suspension etc and wheels, my car is completely stock, an 88.
What should I do? does anyone else have this problem? Should I write to pelican and ask for new parts?
RoninLB 12-31-2008 04:47 PM
you might be able to eyeball or feel the play, or just confirm it by hand wobbling the tires.
if you confirm any play in a ball joint or tie rod I'd change all 4.
old man neri 12-31-2008 04:57 PM
When I put my kit on I noticed that the boots would fold in on themselves and make a distinct sound. However, this was only noticeable at the extremes of the steering range.
And you are sure this is the kit from Pelican not a ebay one? There are two different manufactures out there; one has a good rep and the other one...well..not so much.
Every last nut and thread was torque correctly?
Bart_dood 12-31-2008 09:36 PM
I'll check again tomorrow and be more careful to pin point exactly where its coming from, it did seem to be the inner joint, but I'll check everything it tight.
