Rear suspension bushing
Hi
My Weltmeister bushing docent fit so well.
The bushing outside is to big to fit in outside holder.
The bushing is 75mm in outside and the hole is 73.5 mm.
I think that 1.5mm is to much to compress.
What is your experience?
I have not take apart the other side yet.
regards
tom
/tom
911 sc -83
944 -86
KTM 125cc
Old 01-01-2009, 04:06 AM
If they are rubber (neatrix), then keep pushing, they are the right size. Use some silicone lube to fit them a bit easier. If they are hard plastic, I can't answer as I've never used those.
Tony G
2000 Boxster S
Old 01-01-2009, 05:30 AM
Used Up User
imcarthur's Avatar
Use longer bolts in the bracket to force fit it in. You might need several sizes. Start with 2 long (enough) bolts. Screw then down to their max which will force it in aways. Then use another smaller length & bolt it down to it's max & repeat etc until you can use the stock bolts.
Ian
'87 Carrera Cab
Old 01-01-2009, 05:57 AM
Air Cooled Addict
Joe V's Avatar
Tom,
I had the same issue with my Weltmeisters. You have to force it.
Do you have any clearance at the inner diameter around the spring plate tube? If so, it will be picked up when you press it into place. Make sure you scuff the bushing surfaces and slather it with silicone grease to keep them from squeaking as much.
I used a belt sander to reduce the outer diameter until it had a snug press fit.
Good luck and Happy New Year!
Joe V
'84 Schwartz 911 Carrera 3.2
'91 Specialized S-Works M2 - Gone but not forgotten
'12 Trek X-Cal : American Classic - XT brakes/shifters/derailleurs - carbon goodies
'13 Trek Madone 5.2 stockish
Old 01-01-2009, 06:19 AM
Hi
Thanks for yours inputs.
Bushing looks that the are made of some type of plastic material.
I have some clearance at the inner tube. I think that i need to reduce the outer diameter before.
I think the best way is to press the bushing on the outside holder before assembling the rest.
Thanks guys and have a good new year with your cars.
tom
/tom
911 sc -83
944 -86
KTM 125cc
Old 01-01-2009, 06:36 AM
Originally Posted by tom.langborg View Post
Thanks gays and have a good new year with your cars.
tom
WHOAA...
Tony G
2000 Boxster S
Old 01-01-2009, 06:42 AM
Sorry "GUYS"
My spelling help was not helping me.
I am so sorry.
regards
tom
/tom
911 sc -83
944 -86
KTM 125cc
Old 01-01-2009, 07:32 AM
Oh Haha's Avatar
Sorry "GUYS"
I am so sorry.
regards
tom
it happens.
Hey , do you know a guy there named Markus?
I'm just goofing on ya. Welcome to Pelican and good luck on getting your car back together.
Pacific Blue
Wayne
Last edited by Oh Haha; 01-01-2009 at 07:49 AM.. Reason: Note to self: find something to do AWAY from Pelican today!!!
Old 01-01-2009, 07:48 AM
Sorry "GUYS"
I am so sorry.
regards
tom
Happy New Year!
Tony G
2000 Boxster S
Old 01-01-2009, 07:55 AM
Somatic Negative Optimist
Gunter's Avatar
To,
+1 with the above.
Reduce the outer dia. if needed, file the edge at an angle of about 15 deg. to get a lead, use Silicon grease, press the bushing in half-way and see how the shaft fits on the inner diameter.
If the fit is good on the shaft with the right clearance, push the bushing into the housing all the way and continue.
Use Silicon grease inside and outside of the bushing.
Consider pulling the torsion bar out, lube the splines with bearing grease and re-install.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-01-2009, 07:57 AM
MBAtarga's Avatar
I installed a bump steer kit during the same timeframe of my Welmeister bushing install on the spring plate assembly. I found that the original steering rack bolts that were removed as part of the bump steer kit were the exact size (diameter, pitch, length) that I needed in order to start the bushing spring plate covers to be pulled over the new bushings - just like Ian (imcarther) mentions above. No resizing/chamfering of the bushings is required - but a little grease doesn't hurt.
Mark
'83 SC Targa - since 5/5/2001
Old 01-01-2009, 08:48 AM
I once installed a set of those. The proper way is to turn them in a lath to fit. Having said that I sanded the OD on mine to get them close and then forced them in. This made the inside diameter to small so I took a barrel sander and opened up the ID till the arm would fit without binding. This an inexpensive track style bushing. They are known to be a bit stiff and sometimes squeak so use the Weltmister lub that is made for them.
Next time around I went with the Neatrix rubber / stock style bushing.
Most on this board worship at the church of Elephant Racing, Polly Bronze Bushings so I would not be surprised it you don't get beat up over the Polly Weltmister bushings.
Old 01-01-2009, 09:59 AM
PRO Motorsports
Tyson Schmidt's Avatar
If you have to force the springplate together when using plastic bushings, you're not going to be happy with the result. You need a bearing like action with the plastic, or they will bind, squeak, and give a harsh ride.
It's O.K. if the bushings are tight in the chassis, and the spring plate cover, but once these are in, the bare springplate should easily slide into the bushings. If not, you're going to hate the results.
With the rubber Neatrix, tight is fine, since the rubber actually twists during suspension movement just like the factory bushings. These are much more user friendly to install.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 01-01-2009, 02:03 PM
