What's the difference between the 930 & 911 steering rack?
Is it just the input ratio?
Thanks, jp |
Does any one know the answer to this question I would also like to know.
Are the ratios the same? Is the 930 stronger in some way? |
The steering ratios are identical, the housings are slightly different to accomodate the 930's anti-dive suspension geometry...:)
Steve,
So the 930 isn't stronger or have larger internal gears or anything? How difficult is it to rebuild the rack with quick ratio gears and is a quick ratio set up stronger, weaker, or the same as stock? And lastly do you regularly rebuild or install the Quick ratio gears? |
| All times are GMT -8. The time now is 02:59 PM. |
