she squats back and shakes her nose...
After spending four whole days constantly driving my 78 911 SC, I've noticed that she likes to shake her nose while tooling along in a straight line at highway speeds. Nothing drastic, but enough to notice and require the most suttle input to keep straight. We're talking 75mph and above. Does anyone have any ideas? No chin spoiler or tail. Alignment? Thanks for the input!
2008 Porsche Cayenne S
2004 Porsche 911 Carrera
Old 01-12-2009, 11:25 PM
Driver8's Avatar
I would start with an alignment. But it could also be the tires. What type of tires are you running and how old are they? I don't think you are running at the speeds were a spoiler would make much of a difference.
Aaron
Old 01-13-2009, 05:39 AM
vash's Avatar
alignment.
poof! gone
Old 01-13-2009, 08:09 AM
450knotOffice's Avatar
I'd check the alignment first.
Old 01-13-2009, 08:28 AM
MBruns for President
JeremyD's Avatar
I'd check your tire pressures first - then alignment
Old 01-13-2009, 09:00 AM
Band.
Balance your tires, then alignment. Then a triangulated strut brace, turbo tie rods. And maybe a bare-metal respray, and oh rebuild your engine with twin plugs and 9.8:1, and webcam 20/21 cam profiles and a megasquirt and then
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 01-13-2009, 09:23 AM
Good idea, Jeremy. Go with the simplest item first (although my feeling is that the tire pressures aren't causing this issue, but check anyway).
Old 01-13-2009, 09:48 AM
Is tire "squirm". Could there be a broken belt on those radials? Look at them closely to see if there are any bulges. I think alignment would gradually move you to one side or the other that's correctable w/ steering; the squirm you describe sounds more like a broken belt or some other weirdness going on w/ a tire.
regards,
jlex.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 01-13-2009, 10:38 AM
Tire balance? A chin spoiler helped my 87 but I had a wandering issue.
Antonio
88 M3 NASA gts2 ptc
Old 01-13-2009, 02:41 PM
Designer King
Paulporsche's Avatar
If the above don't cure it try these:
Make sure the car has a slightly nose down attitude--about 1 degree when parked on level ground. Start w/ 29 psi front/34 psi rear pressures cold.
Make sure your shocks are good.
I like a little more neg camber in the fronts than the stock setting. It feels more secure to me.
I also have a front SC spoiler w/ no rear spoiler. Again, to me it feels more secure @ 75 than a 911 w/o one.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 01-13-2009, 03:15 PM
gtc gtc is offline
abides.
gtc's Avatar
I developed the same feeling last year... my alignment was way off, especially in back. I think I had positive camber on the rear wheels.
Graham
1984 Carrera Targa
Old 01-13-2009, 05:03 PM
ShakinJoe's Avatar
Try a HUGE rear wing. It will lighten up the front end where you won't feel the wobble.
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 01-13-2009, 05:19 PM
If the tires check out okay, you may want to pay attention to what Paul says regarding the nose.... when I first got my '85, I remember thinking these things aren't very stable at 65mph & above ... felt like the car was wandering. I discounted a problem w/ the steering rack & just thought that's the way the car was ... WRONG. Had it aligned due to some weird tire wear & as part of that procedure, they put the nose at the correct angle to the car. Made a huge difference! What was happening is that the air wasn't flowing over the top like it should to hold the nose down... the front was too high & therefore it was lifting the car, causing instability at higher speeds. Like Paul says: make sure the nose is down.
regards,
jlex.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 01-14-2009, 07:53 AM
Thanks for all the advise, I will try them and report back on what fixes it! Take care
Old 01-14-2009, 09:03 AM
vash's Avatar
yes. curious that you say your car "squats" and then shimmeys...
ever drive a loaded down pickup truck? shimmey. i still think alignment. please let us know.
poof! gone
Old 01-14-2009, 09:13 AM
3.2 CAB's Avatar
Don't forget to check the front wheel bearings for proper adjustment. Loose front wheel bearings can cause a similar type event. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-14-2009, 09:15 AM
