speedman's Avatar
sticking gas door
does anyone have an easy or good way to lubricate the cable that operates the gas door. I can't get anything in the area to lube.
Rick T
Old 01-04-2009, 08:34 AM
burgermeister's Avatar
You can take the cable out to lube it. It's a bit of a PITA, and it's a 2 person job putting the cable back in. The clamp by the fuel door latch needs to be held with something (needle nose vise grips?) when undoing the screw or the cable will kink & break. Once it's off, the cable just pulls out.
This is a pretty good description of what to do and what not:
Fuel door lock - sticky cable fix
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 01-04-2009, 12:46 PM
speedman's Avatar
thanks for the help. without you i would have broken the the cable!
Rick T
Old 01-05-2009, 08:45 AM
