-   -   Conversion 964tip to 964manual (http://forums.pelicanparts.com/porsche-911-technical-forum/449755-conversion-964tip-964manual.html)
Porscheke 01-05-2009 03:34 AM
Hello
Is it possible to change a 964 tiptronic car into a 964manual (gearbox)
What has to be changed/ swapped?
-Remove computers tiptronic
-Swap tiptronic gearbox into manual gearbox
-Change hand unit in the center console
But I have no idee what else...
...anyone done this before and any idee on the costs?
Bill Verburg 01-05-2009 05:55 AM
pedals and hydraulic lines, the clutch is hydraulic and feeds off the brake hydraulics.
My opinion, if you want a manual car sell the tip and buy one. You will be way ahead of the game.
emcon5 01-05-2009 07:21 AM
Originally Posted by Bill Verburg (Post 4397989)
My opinion, if you want a manual car sell the tip and buy one. You will be WAYahead of the game.
What Bill said, with emphasis added.
Elombard 01-05-2009 08:22 AM
Big problem is the Gear boxes are frigging expensive!
Pete000 01-05-2009 08:35 AM
Its only money...SmileWavy
Porscheke 02-22-2009 12:14 PM
What about the wiring?
Is it removing the tiptronic module & change it with a manual?????
Gearbox should not be a big problem
Pedals & hydraulic lines should also be do able
But my biggest concern is the electronic part.
Does anyone has some diagrams are does anyone on this forum done this swap?
Hope someone can help me
Regards
Porscheke
