Conversion 964tip to 964manual
Hello
Is it possible to change a 964 tiptronic car into a 964manual (gearbox) What has to be changed/ swapped? -Remove computers tiptronic -Swap tiptronic gearbox into manual gearbox -Change hand unit in the center console -.... But I have no idee what else... ...anyone done this before and any idee on the costs? |
pedals and hydraulic lines, the clutch is hydraulic and feeds off the brake hydraulics.
My opinion, if you want a manual car sell the tip and buy one. You will be way ahead of the game.
Hilbilly Deluxe
What Bill said, with emphasis added.
Big problem is the Gear boxes are frigging expensive!
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Its only money...
Work to Live, don't live to work... |
What about the wiring?
Is it removing the tiptronic module & change it with a manual????? Gearbox should not be a big problem Pedals & hydraulic lines should also be do able But my biggest concern is the electronic part. Does anyone has some diagrams are does anyone on this forum done this swap? Hope someone can help me Regards Porscheke |
