S caliper banjo fitting crush washer part number and source
I need to replace the crush washers on my caliper banjo fittings and it appears as if our host does not have them. Can anyone provide part numbers and a source. Are the inside and outside washers the same part?
Thanks |
IIRC, they are the same part. You will end up buying generics. They are out there.
My fist call would be to Goldline Brakes. I'm sure there are others. Locally, I go to CH Topping, which is the best brake shop I've ever been in. |
Banjo caliper crush washers
I need some too. Normally, I would refurbish and re-use mine, but I seem to have misplaced them. Can anyone comment on size and material. I'd like to source them locally.
Thanks, Bill |
| All times are GMT -8. The time now is 01:15 AM. |
