Guest
Posts: n/a
Send me any answers by the end of tonite!
1. How many fasteners hold in the front dash pad on a 1973 911? Please answer with the total number of plastic snaps, and the total number of embedded studs. 2. On a Mechanical Fuel Injection pump, which direction do you turn the low-rpm or idle mixture adjustment screw to richen up the mixture? 3. What is the part number of the aftermarket points that fit the older Marelli distributors? 4. In what year, did Porsche use a 340 F degree oil temperature gauge module in the dashboard? 5. From 1965-89, how many different production 'tails' were implemented, and what were their commonly-referred to names? 6. Old-style sunroof cables are no longer available. What modifications must be done to the newer 964 cables in order to install them in an 911SC? 7. How many bushings are replaced when upgrading to the bronze pedal bushing kit (non-power brake 911)? 8. What is the best way to fix rocker arm oil leaks? What is the part number that is used in this fix? 9. Which one is the brown chain ramp? 10. Why do you need to place the engine at Top Dead Center (TDC) for cylinder #1 when installing the Carrera Chain Tensioner kit? 11. What is Porsche tool 9191, and what is it used for? 12. How many shims total should you have on your fan pulley? 13. How can you usually tell the difference between a Factory Turbo Look, and a conversion? 14. What popular "office supplies" product is invaluable for installing your headliner? (not glue) 15. What is the difference between the original rear spring-plate bushings, and the replacement ones? 16. On the rear trailing arm of the 911SC, what are the four adjustment nuts used for? (also specify their location from back to front) 17. Besides the engine, list 5 specific differences between the early 912s and the 911. 18. What tool should you always use to disconnect hard brake lines from the car? 19. 'Y' tires are rated for what maximum speed? 20. What issue of Consumer Reports did an indepth overview of motor oils and how they affect your car's performane? -Wayne |
Guest
Posts: n/a
I'll even admit that I am cheating to win this
![]() "1. Enough to hold it on when the targa roof flies off at 150 MPH on the Autobahn. 2. North, unless you are in the southern hemisphere, in which case it would be south. 3. Part #993-964-911SC 4. Trick question - Germans use the metric system. 5. Quack, Shamu, Carrera, Tea time. 6. Put in Calvin's transmogrifier (Calvin and Hobbs). 7. All of them 8. Don't run the engine. Not putting oil in it stops even more leaks. Part #993-964-911SC 9. The one that is not black. 10. If it was alive it might bite you when you stick your hand in it. 11. Muffler bearing replacement tool. 12. All of them. 13. The factory version does not have a "made in China" tag. 14. Thumb tacks - saw it yesterday in a 1974 Oldsmobile. 15. The originals are worn out, the replacement will be soon. 16. Tuning, AM/FM, source select, on/off. 17. The 912 has a two in the name. Top speed. 0 to 60 time. Original sticker price. Current value. 18. Bolt cutters. 19. Higher than a 912 top speed, lower than the 959 top speed. 20. You would trust Consumer Reports for that?!? We are fanatics not lowly consumers! James Adams " all taken from James earlier post, hey I'm not sure if they are right, but I agree with them all. Good work James. WAYNE I NEED THIS BOOK, I WILL NEVER GET MY CAR COMPLETE WITHOUT IT!!!! PLEASE ![]() Well thats enough begging for me, I guess I'll line up and buy it with everyone else. Shawn |
Guest
Posts: n/a
Wayne..I'll step up. I'll buy the book! Just give it to Shawn, okay? NEVER debate with a desperate man...
Guest
Posts: n/a
hi wayne, if i knew all the answers to your questions i wouldn't need that free copy
. bob '68 911L ps i'll just have to gladly buy one at the local bookstore. |
Guest
Posts: n/a
Shawn-
That was too funny! I think you deserve a free copy on comedic merit alone! ROFLMAO!!!!!!!!!! -Eric |
