How do I wire a headlight relay
Hi I wish to add a headlight relay to reduce the volgate going through the column mounted light-switch. But I can't find any info on how to wire it...
Thanks for help!
Old 01-10-2009, 02:37 PM
kodioneill's Avatar
Headlight Relay Kit
This easy-to-install kit uses factory connections and mounting points. With the relay kit, the electrical current travels straight from the battery to the headlight circuit at the fuse box, greatly reducing the load on the headlight switch and the failure prone column switch. In addition, more power is supplied to the headlights for maximum light output.
Fits 911 (1974-89). Maximum 100 watt bulbs recommended.
JWST-911-HLPR
Headlight Relay Kit, 911 (1974-89) [Photo] [Photo]
this is a great deal, instructions included. sold by our host.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 01-10-2009, 02:44 PM
Paul K's Avatar
It's an easy install, kit comes with instructions. You might also want to do a search here, as there have been several threads on this subject.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 01-10-2009, 03:08 PM
HarryD's Avatar
Thanks for help!
Ole Petter,
What is the year of your car. The kit they are referring to is good but the design is for post 1973 cars. If you have any early guy (like mine) some addtioninal thinking is needed since the wiring is slightly different. If you can read a wiring schematic, you can find an old post of mine where i show what I did. Depending on your year, you may need to make some adjustments.
The basic method is to use the signal from your stalk to energize the coil (pin 86) in the relay. The other side of the coil (pin 85) is grounded to complete the circuit. You add a fused circuit (from the battery) to your common contact on the relay (pin 30) and the wire to the headlamp is connected to the normally open contact (pin 87) of the relay.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-10-2009, 03:40 PM
dshepp806's Avatar
Easy,..easy!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-10-2009, 03:41 PM
Banned but not out, yet..
RSBob's Avatar
Relay numbers:
85 = to ground
30 = to battery (with a fuse between the battery and the relay)
87&87 = to lights/accessory you are powering
86 = power from headlight switch or other switched source
besides the fuse between that battery and the relay, be sure to also add fuses immediately after the relay to your 87s, to insure you are well covered. Your battery fuse should be able to carry twice the power than your individual 87 individual fuses.
I just upgraded my H4s with 85/100 watt bulbs. As a result I had to run new high, low beam, and ground wires/fuses/relays. I used (edit: 12 gauge wire, NOT 20) to handle the increased current. Used a 20 amp fuse between the battery and the relay and two 10s (for high beam) 15/7 low beam. I also added ceramic high-temp connectors from the new wires to the bulbs. Be sure to upgrade your ground wires as well as your hot wires, or you have only done only half the job.
I built my own wire assemblies and they are as refined as I could make them but they are still a bit clunky. Bet I spent about $90 on wire, relays, fuse holders, fuses, connectors, etc, (but I wanted high quality stuff) so a preassembled units may be a good option.
Old 01-10-2009, 07:54 PM
HarryD's Avatar
Originally Posted by RSBob View Post
Relay numbers:
85 = to ground
I just upgraded my H4s with 85/100 watt bulbs. As a result I had to run new high, low beam, and ground wires/fuses/relays. I used 20 gauge wire to handle the increased current. Used a 20 amp fuse between the battery and the relay and two 10s (for high beam) 15/7 low beam. I also added ceramic high-temp connectors from the new wires to the bulbs. Be sure to upgrade your ground wires as well as your hot wires, or you have only done only half the job.
Rick,
I hope you made a typo and meant 12 gauge not 20 gauge wire!
Per my sources:
10 gauge - 480 watt capacity
12 gauge - 360 watt capacity
14 gauge - 300 watt capacity
16 gauge - 216 watt capacity
Harry
2020 MB E350 4Matic
Old 01-10-2009, 10:49 PM
Many thanks for your knowledge!
I have an old Hella relay, and I would prefer to use that to buying a new set with wires and all.
So many thanks for the info. I guess it is pretty staight forward, but there was no info printed with the relay, so it was great to get it here from you!
I have opened the column stalk once and bent the internal switch, but it didn't last long and now the full beam is no longer working. So I will try and install the relay and then try to fix the column stalk one more time.
Old 01-11-2009, 05:38 AM
kodioneill's Avatar
you should use at least two relays
1982 chiffon 911sc
Old 01-11-2009, 07:38 AM
Use two relays? One for dipped beam and one for full beam?
Does the Pelican kit offer two relays?
Old 01-11-2009, 01:06 PM
scottb's Avatar
The kits come with relays, wires, instructions. They're almost foolproof. For the money, it's just not worthing messing around with a "home brew" kit.
1984 Targa
Old 01-11-2009, 01:36 PM
RSBob's Avatar
Harry great catch - before I burned some one to the ground! 12 gauge is correct. Edit to original post as well. Harry, thanks again for the initial help.
Old 01-11-2009, 09:40 PM
HarryD's Avatar
They do. The wiring will end up somewhat like this (ignore the circuits for fog and driving lights):
The fuse numbers will change depending on what year your car is.
Harry
2020 MB E350 4Matic
Old 01-11-2009, 10:47 PM
Many thanks!
I do see the wisdom of getting the kit from our host....!
Probably not worth trying to do this on my own.
Old 01-12-2009, 12:58 AM
