jmiemiec's Avatar
901 tranny testing
Hi,
is it possible to test a rebuild 901 tranny prior to putting back in the car? E.g. can the shaft rod be turned in ways which correspond to individual gear changes?
I only swapped the synchros but it would be good to have a "reliable" test prior to installation.
thanks
JM
Old 01-12-2009, 03:03 AM
Slumlord
Porsche_monkey's Avatar
You should be able to use the shift rod and engage all the gears manually.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 01-12-2009, 06:26 AM
I would rather be driving
jpnovak's Avatar
Absolutely, Just clamp the shift coupler in place with the grub screw or use a pair of vice-grips on the select shaft. You will be able to feel each shift fork gate and select each gear. new syncros might be a bit tight to engage and The dog-teeth may not align easily with the input shaft not turning. Just rotate a drive flange to counter-act this problem.
Old 01-12-2009, 07:39 AM
