KillerDynoSoar's Avatar
Starting up my car after 10 month lay off
I have 3.2 equipped back dated 911. I haven't driven the car for 10 months! Sad but true...
Anyway is there anything I should do when starting the car up?
I was thinking about disconnecting the fuel pump, cranking it over to build oil pressure and get oil around the engine. I would then reconnect the pump and fire it up... then go and get some fresh fuel.
Any tips? Or have I got it covered??
77 Porsche 911 3.0 Carrera
58 Porsche 356
55 Chevy Bel-Air
72 Volkswagen Bug, 06 Volkswagen T5
14 Yamaha R1, 14 GSXR750, 17 CRF1000
Old 01-19-2009, 02:42 PM
pcar9119's Avatar
you can just pull you coil wire too. Did you put stabil in the fuel when you put it up. You'll probably want to drain and replace the oil also before starting. Thats what i would do if it was my car.
Old 01-19-2009, 04:52 PM
pozee's Avatar
the following thread has some good ideas...
Basic Question Checklist for Resurecting a Sitting Car
pozee
Old 01-19-2009, 04:53 PM
Thanks for the tips.. the thing is my car had a oil change only 700 miles ago and that was just before I garaged it.
Hmmnn... I need to replace the oil pipes so was hoping to do the oil change then.
58 Porsche 356
55 Chevy Bel-Air
Old 01-20-2009, 03:10 AM
