70 911T Electrical Problem
Greetings Pelicans,
Well I dove into my turn signal problem( See my earlier message re no outside left turn signal and no inside right turn indicator when using column lever). The nearest that I can figure is that the column switch is shot ( it's original). Before I pull it out and replace it I'm seeing another problem.........when the turnsignal is actuated the oil pressure and gas guages fluctuates in sink with the turn signal relay.
Anybody had this problem before and what causes it............a grounding problem but where?
Short circuited in Fallbrook, CA
Dirty Marty
Old 01-12-2009, 10:23 AM
