Replacing 911SC fuel lines
hi. im trying to change the fuel lines from the fuel pump up front to the rear engine compartment any ideals thanks
sylvester
Old 01-12-2009, 07:42 AM
vash's Avatar
dude...what year is your car?
poof! gone
Old 01-12-2009, 08:44 AM
porsche question
its a 1979 porsche 911 sc widebody strosek
sylvester
Old 01-12-2009, 10:27 AM
are the lines in the tunnel leaking? In order to replace those you have to lower the trans partially to access the lines at the engine end.
how about a bit more info on what you're doing exactly.
Tony G
2000 Boxster S
Old 01-12-2009, 11:12 AM
Tom '74 911's Avatar
I've done this. My engine & trans. were pulled at the time and I replaced the fuel lines w/AN hose & fittings. Here's some places to start reading:
How hard is it to change the fuel lines?
Fuel lines in Tunnel?
Pic of center floor/tunnel section?
There are other links w/in some of those threads.
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 01-12-2009, 02:48 PM
porsche question
yes.. its leaking in the tunnel somewhere i can smell it inside there.
sylvester
Old 01-12-2009, 04:08 PM
911 tweaks's Avatar
obviousley don't use the car till this leak is fixed & all of the lines are either inspected or replaced.
Keep us posted and good luck!
Bob
I live for 911 tweaks...
Old 01-12-2009, 05:20 PM
porsche question
ok.. thats what i was thinking to thanks for the help
sylvester
Old 01-12-2009, 06:52 PM
frankc's Avatar
I'm in the process of replacing the lines now...
Should I replace theses brake and fuel lines?
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 01-12-2009, 10:02 PM
