-   -   Pertronix for 008 distributor? (http://forums.pelicanparts.com/porsche-911-technical-forum/450999-pertronix-008-distributor.html)
Gogar 01-12-2009 04:02 PM
I have a Bosch 008 distributor on my 73.5 CIS 2.4 motor. I'm considering installing a Pertronix, but there is no Pertronix listed for the 008 distributor. Can I use the one listed for the 009,010,003,004, 005 Distributor? Or is something else the "correct" one?
TIASmileWavy
Gogar 01-16-2009 05:18 PM
Bump. Can't find much about this.
wowzer911 01-16-2009 05:46 PM
Use the one for 73.5-77 from our host.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_UPrc91_pg20.htm
dlague 01-16-2009 07:05 PM
I had the same question and problem about a year ago. the 73.5-77 fits the 008. I learned the hard way and had to return the wrong one. let me tell you this is a great modification. I have had the Pertronix Ignitor II in my '73 for almost a year now and I am very impressed. the timing stays spot on, the dwell does not wander. Runs much better at higher RPM. Great device.
Also easy to install. You just need to get switched 12vdc there to the pertronix.
itsa6911 01-17-2009 05:21 PM
I have the Bosch points dist 0 231 169 008 in both my
68 (2.2 Webbers) and my 73 (2.4 Zeniths/MSD)...both with vac adv. plugged off...
I've always understood they were unavailiable for this dizzy...
Which pertronix will fit ?????
Because I love points so much, I'll order two on monday!!!
itsa6911 01-20-2009 04:20 PM
dlague, PM sent
