Dizzy help and questions (with pics)
Ok......here's the background.
My car is a '77S with Pertronix. The wire from the Pertronix unit got frayed from the rotor and broke off. I bought a new Pertronix unit from our host. Through searching I understand I've got to set the static timing. Here's how the dizzy was set when I opened the cap with the car at TDC ![]() I set the crankshaft to Z1 ![]() Pulled the dizzy and set like this ![]() Car idles perfectly, but runs rough. Searched some more and saw an article about valve adjust with this picture on how the dizzy SHOULD be set????? ![]() I guess I've got the dizzy screwed up.......what's correct? Thanks for your patience and help.
Sean M '77 911S Targa Ice Green |
The picture from the valve adjustment is only to show how to set the dizzy so that the engine starts. You have to check the timing with a timing light. This is the best way. If you don't have a timing light, you can advance the dizzy until you start to get detonation with a load and full throttle - like going up a hill. Once you get detonation, back off the timing a little. This is not recommended as these cars are sensitive to detonation and some cannot tell when detonation occurs. You really need to check the timing with a timing light.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Sean, botom pic is right.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Thanks Aaron.......that's what I thought. In looking at my 101 and Bentley, it never showed a rotor like mine so I wasn't sure where to line it up.
I will get a timing light as well. Thanks
in the top picture you have the ground for the rev limiter pointing to #1. the center contact moves outward as RPM's go up until it makes contact with the ground.
