NEW SOUND CLIP! Valves, chains, or exhaust leak? OH NO
Here is the NEW sound clip holding the recorder out of my window while parked.
http://mywebpages.comcast.net/dimeified/badnews2.wma Throughout the clip im feathering the throttle. The rattling sound masks out the normal engine noise for the first half of the clip. Towards the end i raise the rev a little higher and you can hear the normal engine sound behind it as the revs raise. 1- It's been determined through exhaustive (no pun intended) work that the problem is not the cat or muffler. I removed cat and reinstalled cat-bypass. Used brand new gaskets. Wirewheeled flange surfaces on cat-bypass, muffler, and the 2 flanges that the cat connects to. Tightened muffler straps completely and backed off 2 turns. This is an mkexhaust 1st gen no baffling muffler, so that cant be the problem either. 2- It's not the alternator or fan. I have disconnected the fan belt and ac belts, sound was still there. 3- Held hose to chain boxes and ear during noise, did not hear anything alarming. 4- I also haven't had a valve adjust since i had the car 3 or 4 years ago. 5- I use mobil1 15w50 oil, oil level is at proper level. 6- Only happens when car is up to operating temps. 7- Easiest way to get problem to reoccur is driving at constant speed in the 3k rpm range. This may be sympathetic vibration from the motor or exhaust causing something else to rattle. 8 - It seems shifting has gotten harder the past couple days. The shift lever is harder to move, and moving into gears is a little more difficult. However the clutch pedal pushes down alot easier. Yesterday when shifting out of 2nd gear, the transmission threw it out for me, with great force. Here is the old sound clip from in the cabin for reference. http://mywebpages.comcast.net/dimeified/badnews.WMA
1984 Porsche Carrera Cabriolet - sold, regrettably 2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably 2005 Mercedes C230 Kompressor Sport Sedan - now... Last edited by dimeified; 01-14-2009 at 07:09 AM.. |
Its hard to tell from the sound clip...its not very clear. From what I can hear, it sounds to solid to be an exhaust leak.
Michael 83 SC Coupe |
the only thing i can here is your shoes on the ground.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
It sounds like a rod bearing but could easily be an exhaust leak.
Tim Lynn 84 911 Carrera PCA E Stock #278 |
UNDER CONSTRUCTION!
i have listened to this a number of times and trying to determine what sounds your making and what the car is making is difficult for me. if it does it again and you want to make a recording set the recorder down on the ground in front of your rear tire this will keep some of the clutter down.
"sounds to me like a cheff preparing a meal while driving his porsche" have you added oil since this clip? or have you done anything different ? as why is the noise no longer there. hope you get this figured out as these kinda things are a bit worrysome for the driver. cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
I did try adding oil, and i also let the gas tank run close to empty and refilled with fresh gas. Problem was still there for days. Should i use the right rear tire so the exhaust system doesn't bleed into the recording?
1984 Porsche Carrera Cabriolet - sold, regrettably 2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably 2005 Mercedes C230 Kompressor Sport Sedan - now... |
UNDER CONSTRUCTION!
that would be fine i just cant get a clear idea of what is really the car and what is you.
give us another try and lets see what we get. cheers ed
Southern Class & Sass
Check that the muffler straps are tight.
I had a rattle/buzz that would occur occasionally at startup. I spent hours trying to figure out what it was. Then I happened to notice the muffler strap was just loose enough that it could move.
Dixie Bradenton, FL 2013 Camaro ZL1 |
I've added a new sound clip for everyone to hear, this one is very detailed. Also, i have cleaned up my information in the thread, and put it all in the first post.
