wrxnofx's Avatar
Originally Posted by Jp-oh View Post
I love how this has serendipitously been bumped up just at the time in need to get my drivers side assembly out. I can get the two screws out easy enough but the assembly still seems very much secure. Do I just need to "persuade" it a bit?
You do have to remove the drain tubes in order to get the housing out, but it will still wobble around even with the tube still installed.
There isn't anything else holding the housing in other than the seal around the perimeter. Perhaps your PO glued the seal.
I just pulled on the sides of the housing, and the seal let go. I still need to get the harness disconnected, however.
1987 911 Carrera coupe - Guards Red
2005 Mini Cooper Convertible (R52) - Wife's car
Old 04-16-2014, 05:16 AM
CiscoSF's Avatar
Does anyone know the part number for the long seal that goes underneath both housings and the "PORSCHE" lens?
Francisco R.
1986 Porsche 911 Carrera Coupe
Old 09-12-2015, 11:43 PM
wrxnofx's Avatar
Should be 911 503 085 05.
EDIT: Assuming you're asking about your '86.
Old 09-13-2015, 03:19 PM
CiscoSF's Avatar
That's it, thanks.
Also, does anyone know the difference between "Tail Lamp Bulb - 12-volt, 21-watt" and "Tail Lamp Bulb (12-volt, 21/5-watt)" on 1986 Porsche 911 Carrera Coupe - Lights and Lenses - Page 2 ?
Francisco R.
Old 09-13-2015, 08:03 PM
Dial 911
A horse with no name's Avatar
Hi, the 21.5 - 1157 - is a brake light bulb. The other, 21 is a 1156 tail light bulb.
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 09-13-2015, 09:40 PM
CiscoSF's Avatar
Got it, thanks.
Also, I want to reiterate the importance of taping the bumper before taking the housing out. I thought I would be gentle and that would be enough to avoid scratches. Now I have a scratched bumper.
Francisco R.
Old 09-13-2015, 10:31 PM
Cool No problems with replacement
After reading the blogs I had significant concerns about starting the replacement of lenses and gaskets. After reading several different threads, I got started and everything went perfectly...screws came out without issues, assembly was in good shape and gaskets were replaced without issues. Gaskets were 30+ years old, but total time to replace both sets was less than an hour. I suspect I was lucky! Only issue was one drain tube was pretty deteriorated.
Old 02-13-2016, 05:14 PM
ASTI
Ruby1983-911sc's Avatar
Thanks to all who have shared their knowledge regarding the difficult tedious task of removing a tail light assembly.
I found the screws needed for the lock nut (part #99950731212). The part# N10081801 you can call your local Porsche dealer and they will order them for you. The screw is a M5x0.08x16 SS
"Yes, I think to myself, what a wonderful world."
Louis Armstrong
Old 11-08-2017, 11:12 AM
Formerly known as Syzygy
Canada Kev's Avatar
I just picked up the screws art a local McMaster Carr. Way less expensive. I had to get the nut from the dealer, though. Pricy. The threaded insert looked to be made of bronze or similar? Perhaps that explains why I managed to just unscrew three with no issues and only had to struggle with the one closest to the oil tank. Of course it was the most difficult to access. It required lots of swearing.
Kevin
Old 11-08-2017, 04:53 PM
know what matters
cultusrider's Avatar
Exclamation
Originally Posted by burgermeister View Post
I reccommend AGAINST the imapct driver after having tried it just yesterday. I successfully broke the captive nut loose from its clip on the RH nut of the RH tail light. Which made it free spinning, and thus difficult to even drill out the screw. Of course, access to the nut is limited by the oil tank ...
I did eventually manage to get a vise grip on the nut enough to gently drill out the screw.
oh boy, exact same situation for me tonight - so happy to have found this thread but to makes things even more interesting, the pilot hole was drilled without issue but the second drill bit broke off inside the screw! Now looking for a way to cut off the captive clip / nut and hoping a pair of narrow bolt cutters will do the trick!
Old 06-20-2018, 08:19 PM
know what matters
Originally Posted by atc_marty View Post
Reviving this thread for a few questions. Second, since my nuts are spinning freely I don't see how drilling out the bolt is going to help. The head isn't rounded out and my screwdriver has plenty of grip. I think I'm missing something here...
Replace the tail light seals, I thought. It'll be easy, I though! D'oh!
lol, you are me, I am you - but in the future, as in tonight
Old 06-20-2018, 08:39 PM
know what matters
Smile
Assemblies out! Now waiting on new captive fasteners from Pelican. Wahoo
Old 06-22-2018, 06:59 PM
know what matters
once the 2 small screws holding the backing plate in place are removed which went much better than the housing fasteners, you can use a flathead screw driver and some gentle persuasion to “pry” the two sections apart which reveals the amazing sealer still in relatively good shape after all these years (31, my car is an 87’).
Old 06-22-2018, 07:03 PM
