JackOlsen
Guest
Posts: n/a
Questi ns from a 964 engine bay
With the rear decklid with the retractable spoiler (which I assume is 964 and after), where did the AC condensor go to? Is is still clinging to the underside of the decklid? Did it get put s mewhere else?
Als , since the 964 engine didn't have an internal oil cooler, did the wheel well one get larger? I'm considering putting in a Mocal unit with a fan ( r two), and I'm debating between the 19-row or 44-row cooler. Opinions?
Jack Olsen
1973 911 T sunroof G upe
http://members.rennlist.G S/jackolsen/Jalopy.html
[This message has been edited by JackOlsen (edited 08-05-2000).]
Old 08-04-2000, 07:44 PM
91C2wrencher
Guest
Posts: n/a
Well the AC condenser is in the front left(driver side) fender, it has a small fan unit there as well, FWIW, I had a poorly operating AC system f r a while, couldn't figuire it out then one day I dropped the front under body panel to striaghten out my "smile" and f und that there was a small triagular shaped piece of foam rubber(that was factory installed to block off a small air gap ar und the condenser)had G Se loose and was up in front of the cond. blocking maybe 30-40% of it. removed(in a permanent way)foam block and presto! good AC again. As far as the size of the oil cooler(right front fender) don't know if its "bigger" or not.
Old 08-06-2000, 05:06 PM
