Banned
sporto questions no spark
hello
I am trying to get a a 70 911 sporto running, I am not getting any spark, but before I test cds system, i was wondering if because it is spotomatic , do i have to do something special to get spark/start , the car is in "N" and no brake on thanks i know it a dumb question , but since it is 'AUTO" i was thinking there might be something about the spark./ start thanks |
Do you hear a whine or any sound from the CDI when you turn the ignition on?
pozee |
Banned
hi
no i do not , it is a permatune, i did not think they made a sound, |
UNDER CONSTRUCTION!
if the car is cranking over then it has nothing to do with the sporto tranny. your car shouldn't crank if in gear should only crank in park and neutral.
check the points and all basics if the cars has been sitting i like to roll every fuse in its holder as it will help making contact if a bit crusty. cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
You are right. I understand that Permatune's do not hum/whine.
Did this happen suddenly or has the car been sitting for a while? Is there voltage at the coil? Have you tested the ignition coil?
pozee |
Banned
the 911 has been sitting for yrs, , I get one blue arc from the coil plug wire with the key turned into the on position, nothing once cranked
UNDER CONSTRUCTION!
sounds as if the points are closed or a short in the dizzy.
ed
68Sporto
The sporto usually will only prevent the car from cranking if it isn't happy.
Tony Porsche owner since 1967 1998 Boxster 1968 911 Sportomatic project |
