85 Running Rich at Idle Only
Gentlemen,
Sorry to bring this up again, but for those who had rich idle issues when warm. Did you find the fix? I have checked everything twice, CHTS, ICV, Vacumm Leaks, DME, Relay, AFM, Fuel Pressure, New Refurbed Injectors, Plugs and still can't get her to lean out no matter what I do: AFM adjustment screw has been turned out 9-10 counter clockwise and still reads top fluctuation of 0.81 volts on the O2 Sensor. I've even taken the screw completely out and plug the hole with my finger and finally got a 0.63 top fluctuation. I re-installed the Stock Chip and no change on volts. Soon as I connect the O2 Sensor she would start to lean her out at idle lowering the RPMs 40+/-. She has perfect runs in all gears with proper Mixture, Strong and Steady. She only acts up on occassional stops or stop and go traffic. TIA SmileWavy |
You might want to look at your AFM flapper, sometimes the surface gets a little dirty or something keeps it from sealing completely. Result, you get more air past the flapper which works just like a vaccuum leak.
Thanks DonMo. Will check that out.
Also check the flapper stop, its a metal L piece with rubber coating. Its on the air filter side.
Thanks Bart Dood.
Draco - I don't think it does, but, any chance this may have something to do with the injectors you used?
Actually she got leaner with the alternate BMW injectors. The OEM injectors caused a 80+ RPM drop.
Thanks though, I appreciate it. |
Great, Thanks Bart Dood!
BTW, where is the VFM (Variable Fuel Meter?) What should be the out put? TIA so Much! |
I had a similar issue a few years ago. My issue was two of the pins for the AFM connector pushed back when I installed the connector. You might pull the rubber boot back and make sure all the pins are fully seated.
I will check the connector. Jim |
Jim, STOP fiddling with your car and drive it!! ;)
I hate being so freakin anal. |
AFM Failed 9 Volt Bench Test
:p
Well it appears the culprit is my Air Flow Meter (AFM or MAF). Check Connectors = Good Checked OHMs = 1.89, Good Voltage Check with a 9 Volt Battery reading 8.88 on DVM Here are the results: OHMs: 1.89K = Good 0.56: Barn Door Closed/or at rest 1.20: Slowly Opened to first mark on the potensioner 2.46: 2nd mark 3.67: almost 3rd mark then 6.07: for a split second then 4.17 - 5.34 until right before the last mark then 7.23: for a split second then 2.18: fully open Barn Door. I think something is wrong with my AFM. Someone said I should use an analog meter but the 944 guy used a DVM too and he stated he got 0.50 volts at rest and gradual and steady rise in voltage until full throttle 8 volts. I wanted to verify this so I was fooling around with the arm and got it to read 4.23 volts at rest and slowly moved the arm and it rose steady and gradually and managed to go 8.83 volts at full throttle/open barn door. I think the Sfernice 8404 Potensioner is bad. I got nervous so I put it back. Test Drove and yeap same thing, rich at 0.82 volts at O2Sensor disconnected. |
Update:
SUCCESS! It was my AFM. In fact the new used 40K '88 production AFM (indicated on the Potentionmeter 8804, April 1988) was turned in all the way and I got 0.63-0.69 volts on the O2 Sensor. I had to lower my base idle, very smooth and responsive. I will use an LM1 to fine adjust the AFR Thanks Kevin & Steve. |
Ive seen where you check the voltage on your 02 meter to determine if your running rich or lean. I assume from the previous post that your shooting for around .65. As you know I'm still trying to sort my 3.2 out and if I understand it correctly a reading of .3 would indicate lean. My 02 sensor is on the drivers side and it reads .3, while the LM-2 sensor on the passenger side is reading 14.5. I welded a bung on the passenger side.
So is the drivers side of my motor running lean? If it is, what would cause it. I wonder if an injector was clogged, if this would cause it. Its about the only thing I havn't replaced. I may try and run some techron threw it and see if it helps. |
FYI, the response function of a narrow-band O2 sensor is almost a step function. In normal operation the O2 sensor output bounces between 0.1 and 0.9 volts constantly as the Motronic adjusts the mixture. It is very hard to tell whether you are lean or rich by gauging the raw output. The bouncing signal requires an integrator with a very slow time constant to get a proper reading. A DVM is not suitable here.
That's why a wideband sensor is what you want here. It's output is much more linear over a wider A/F ratio range. Ingo |
Update: Had my buddy hook up the LM1 and after some tweeking we got 14.7!!! The new AFM and new refurbed BMW "364" Fuel Injectors was defintely leaner than my old ones and we had to loosen the tension spring on the AFM to get the proper reading on the LM1. The reason for this, the AFM appeared to be too tight so it would not allow the WOT to read at 13.1. It was reading 14.2 at Full Throttle (WOT). Once loosened 4 clicks we got the desired readings. The idle is so smooth now. I never knew how the idle was supposed to be but now I know. Can't get the stupid grin off of my face. :D The RPM idle down from speed is so smooth and settled right down to 880RPMs, dead on. http://img.photobucket.com/albums/v5...Photo-0023.jpg |
Now go drive your car and stop playing with it.
Is there any reasion I can not test the AFM in place with the key on or using the 9 v battery approach?
Draco, when you say loosened 4 clicks, do you mean you adjusted the 'clock spring' to change the resistance against the barn door?
I seem to have the exact same problem but I tested the AFM and it swept evenly across the range when hooked up to a 9V battery. I don't know what else can cause a rich running mixture.
Dennis |
I am suspecting my Fuel Pressure Regulator. waiting on Doyle to examine his after swap out. Stay tuned or my BG44K thread. SmileWavy
Interesting thread,..adjusting that spring tension in the AFM is "serious" business.....but it sounds like the instrumentation was inplace to meter! Good news!
I've still NOT installed the part yet, but am trying to arrange the schedule to get some time,..(shouldn't take THAT long just for the part changeout). I don't have my gauges to get the pressure readings post install-even pre-install although my Wrench said they were spec after the fuel pump changeout. You know, even after the changeout, it may be "prudent" for me to keep the original around, just in case, in perfect working order,..once I'm comfortable with the fresh Bosch piece,..THEN, I'll cut that MOTHER apart and see what a ~23 year old diaphragm looks like? I WILL get to it, DRACO. Hoping to autopsy the oil and fuel filters (post BG44K) on Saturday...Rusnak is "interested" in my insolubles,..so, let's go look for such matter, no? Best to you! Doyle |
I recall reading (long ago) that some piece of the AFM calibration (factory) involved use of laser...anyone know (or have heard of) this?
Best! Doyle |
I was told they were individually calibrated at the factory. Not sure how though.
Yeah, I don't think I'd touch the clock spring. That's what you buy a MoTec for.
I have to go back to source material to re-think Crashr's question. I also should check my own fuel pressure with and without the fpr connected for comparison. |
I have a spare AFM, while driving around to zero in the mapping on my chip, Steve W and I messed with the spring to fine tune her. It worked fine but I was insecure so swapped back to my known good AFM.
when one has an eprom and a dyno, one messes with the clock spring with impunity, lol.
:D, well I got the LM-2 now, all vacuum leaks found and fixed. Once I can verify the state of the FPR, will be re-tuning :D
Oh, you sick-o!!!! ....so, how do you like it? Is it awesome? lol :::jealous:::
It is pretty awesome, especially with the RPM reader and SD card to capture the data.
It is here for my buddy's, so when you in town stop by and we can see what she is doing ;) Always felt bad bothering Steve W, everytime I want to check my AFR. He is so busy and gracious with his time. Well I told him he has a back up if he every needs it :D |
I never did get the software working for my LM-1. I sorta wing it with the computer in my lap all the way up to max rpm. You need a chip burner now, brotha!!!
| All times are GMT -8. The time now is 11:49 AM. |
