Porsche Crest Track tire camber and pressures?
I am trying to find some good data as to tire set up on a well dialed in 911 to use as reference.
Thus:
What tire are you running?
How stiff is you car (stock, street/sport, full race)?
How much rear neg camber?
What are best tire presures, hot or cold?
Rim width and tire size?
Is it working well (good lap times, equalized temps)?
Or what ever you think is relevant or belive to be a best practices set up.
Big thanks in advance.
Old 01-20-2009, 04:33 PM
My thoughts in bold.
Originally Posted by 911st View Post
What tire are you running? Toyo RA1
How stiff is you car (stock, street/sport, full race)? 22/29 T-bars, 23/23 Smart Racing Sways, Tarret camber plates with monoballs, Bilstein sports, Elephant polybronze (front)
How much rear neg camber? -3 degrees (-2 in front)
What are best tire presures, hot or cold? hot pressures = 34 lbs (all 4 corners)
Rim width and tire size? 7X16 and 8X16
Is it working well (good lap times, equalized temps)? Best setup I've had so far. Follows the Smart Racing suspension guide recommendations (except for shock valving).
Or what ever you think is relevant or belive to be a best practices set up. Toe out in front and toe in in rear has has been the ticket for stability and good turn-in. The addition of negative camber really made a difference in grip and lap times. Balancing weight between front wheels seems to have improved braking stability.
Old 01-20-2009, 06:14 PM
Excellent Jon, thx.
Old 01-21-2009, 07:51 AM
