Tired Member
DaddyGlenn's Avatar
After a couple days driving around with a new ($50) pick up coil in the distributor thinking I solved the issue she died on me today. The engine cut out for about 3 seconds then refired.
Guess I'm back to troubleshooting. I suspect everything and will start over from the beginning.
Anyone know how often the engine wiring harness fails. My 30-year old harness has cracked wire insulation on several wires including the ones that attach to the coil and "green wire." And is there a decent substitute to the almost $500 dollar Porsche brand replacement harness?
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 01-29-2009, 08:44 AM
T77911S's Avatar
Ignition coil
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-29-2009, 09:47 AM
Tired Member
DaddyGlenn's Avatar
Originally Posted by T77911S View Post
Ignition coil
That is what my gut has been screaming all along. But sometimes I like to ignore my gut.
So do I have to use a Permatune coil with my Permatune CD unit or can i opt for the less expensive Bosch coil?
Glenn
Old 01-29-2009, 04:33 PM
T77911S's Avatar
i would get rid of the perma-doom, perma-crap and go MSD.
it amazes me at how coils go bad on these cars. i use to work at an auto elecrtic shop, a long time ago, and i was having trouble with a car, i asked the guru there if it could be the coil, he said likely not, it is rare they go bad, maybe he did not work on a lot of porsches.
RACE CAR:: sold
Old 01-30-2009, 04:29 AM
Learning slowly at times
Sorry to see your having trouble with the 78. If you need a helping hand, not much knowlegde about the car mind you, but just willing to help! Mark
Old 01-30-2009, 04:49 AM
Tired Member
DaddyGlenn's Avatar
T77 - I will go the MDS route once I am again gainfully employed. But for now, I just need to get my hands on a low cost Coil that will work.
Mark - Thanks for the offer. Know anyone with a spare coil lying around?
Glenn
Old 01-30-2009, 06:33 AM
Tired Member
DaddyGlenn's Avatar
I took it for a trip this weekend, fully loaded with camping gear. 75 miles out on Friday and 75 miles back on Sunday.
It only died once on me and that was before it was fully up to operating temp. It fired right back up and didn't give me a lick of trouble after that.
Glenn
Old 02-02-2009, 07:42 AM
T77911S's Avatar
go to advance and get a blaster coil, there about $40
RACE CAR:: sold
Old 02-03-2009, 05:19 AM
Tired Member
DaddyGlenn's Avatar
Brand new Blaster coil in place and still have the problem!
Glenn
Old 03-04-2009, 10:55 AM
kodioneill's Avatar
man, how frustrating.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-04-2009, 11:09 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Have you gone through the basics: Clean and re-seat connectors at the CD box, check for no frayed wires from the distributor (trigger signal), etc. If yes, it, sounds like you CDI box - see my previous post. These boxes do fail and your pattern is consistent with a box that latches up.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-04-2009, 12:55 PM
toddu's Avatar
Faulty fuel pump relay perhaps? (I admit, I haven't read all the thread details)
Todd
'81 SC
Old 03-04-2009, 01:03 PM
Tired Member
DaddyGlenn's Avatar
Ingo
Ingo - This weekend I went through and double checked all the wires...again. I even unwrapped the wiring harness leg that goes to the CDI and found nothing. The problem seems to be accelerating it's frequency and I have to admit that it appears that you are correct and I am going to have to suck it up, spend the dollars and replace the box.
Todd - I have ruled out a fuel issue. This is definitely an electrical problem.
Glenn
Old 03-17-2009, 07:24 AM
Tired Member
DaddyGlenn's Avatar
Finally got a new MSD installed Saturday morning and spent the rest of the day driving all around Pittsburgh. Not a lick of trouble and the car seems to start better, too. The wiring install is pretty ugly but I'll fix that when I have more time and access to a garage and the rest of my tools. For now, I hope I have finally solved it.
Thanks to everyone for their guidance.
Glenn
Old 04-20-2009, 05:15 AM
Connecting Green Wire
Help. Does anyone know about connecting the green wire pigtail. The green wire I bought is only about 4 '', the wire on my car is much longer. I haven;t even found a connector yet. Is there a way to tap into the existing wire? I have searched this sight, but haven't seen anyone else having this problem. This is the only part listed for my 1979 911 SC.
Thanks, Ron.
Old 07-20-2011, 09:36 PM
Tired Member
DaddyGlenn's Avatar
Ron, welcome to the forum. The green wire is a co-axial wire and you probably don't want to try to splice it. Not sure which connector you cannot locate. Pictures would be helpful. I'm having trouble visualizing your situation.
Glenn
Old 07-20-2011, 09:49 PM
