993 HEs on 3.2 - Extended use reports
Looking for any and all perspectives, performance reports, audible opinions, etc...
Street driving, Autocross, DE situations Want to hear from those of you who have done it, Tyson, Ben, ??? Installation problems, challenges, extra bits required... thanks in advance
1985 Carrera Under Modification (SOLD) 2003 Carrera 4S |
I have a stock 85 Carrera motor still running the stock chip although the O2 sensor may not be working which would make me a little rich. I am running the M & K 2 in 2 out muffler and have one side that can be blocked to drop the noise several dB. This old motor made 190 rwhp on a good brake dyno so it makes good power. The dyno guy said that on the other dyno in town it would have been equivalent to 212rwhp(the difference in dyno types). So power is pretty good. My AFRs were good as well but keep my possibly failed O2 sensor in mind.
IMO the sound is great for the track or autocross without being TOO loud. I get complements on it all the time. Our autocross group instituted a 50ft 93dB limit or so and I was able to run both sides open without bing too loud. I took the cap so I could add it between runs to drop it another 8-10dB in case they called me on it. I love the sound although with both barrels open it is a little loud for some of my more uppity neighbors. I plan to try to make the exhaust a little quieter by installing a turbine in the exhaust path sometime in the next several months. One minus is I still do not have heat yet. It's going to take some more fabrication. I had to cut off one of the HE heat duct connections to get it to mount on my engine. I am certain it can be done, but it will take more time and money. I think Ben was putting together a setup for heat. If I was buying one now I'd try to get it all done at once. A couple of the nuts are a @#$%^ to install and get tight on the HE with the rotated flanges. I have fairly wide hands and had trouble getting them in there to tighten a couple of the nuts. I ended up getting help from someone with smaller hands and a special tool. We used the Wurth copper plated nuts that were sized right for the exhaust stud but only had a 12mm outside instead of 13mm. The we used a 12mm Snap On ratcheting wrench that had a flex head on the end. I saw a tool the other day that looked like a ratcheting wrench but had an additional ratchet drive on the end of the handle. If you could get the wrench on the nut and had no room to turn it you could hook up a ratchet driver to the end of the handle and turn the wrench that way. I wish I could remember where I saw it because I was thinking a couple of those might come in real handy. Just my 0.02. It's worth what you paid and not a penny more. If you lean more towards the autocrosses and the DE's than the Q-tips you'll probably like it.
Rob Channell One Way Motorsports 1979 911SC mostly stock ![]() 1972 911T Targa now with a good 2.7 ![]() 1990 Miata (cheap 'n easy) 1993 C1500 Silverado (parts getter) Last edited by Rob Channell; 02-28-2009 at 08:57 AM.. |
Gratuitous pics.....because I can.
Yes, she's no beauty queen, but she's fun and she's mine.![]() ![]()
Rob Channell One Way Motorsports 1979 911SC mostly stock ![]() 1972 911T Targa now with a good 2.7 ![]() 1990 Miata (cheap 'n easy) 1993 C1500 Silverado (parts getter) |
MBruns for President
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
So you believe or know this to be an upgrade in terms of RWHP over the stock set-up? How about relative to SSIs?
Yes, Steve Wong and Tyson Schmidt experimented with these and the sentiments were much better than stock AND SSI's.
JeremyD,
I think you had B&B/Flowmaster. How dose the change to 993 & M&K compare? Are you close to the same power? Or, did you have to add or take out fuel or see and any indications in the AFR's with the change that can lead you to any opinions or conclusions? Thx.
Jeremy,
It appears you have heat from these? Did you drive this morning? Was it warm enough. That is about as much heat as I think I will need.
No - I have not dyno'd it yet - but from my track experience(s) the end of last year, I don't think I am missing any HP - (I tracked down a 997 driven by an instructor, no slouch - and I am no Mario Andretti)
Did not drive this morning as my car is still on jack stands waiting on wheels from Jeff - but yes, the heat works enough for Florida - it just takes the chill out of the cabin. No - it does not provide enough heat to have the top down on mornings like this - With the stock exhaust HE you could cook a turkey in the cabin.
What's the pipe size? Also, from your picture it looks like they prevent the valve covers from being removed or is that just the angle of the photo?
Gone 92 C2 82 Euro SC race car 993 C4S 3.8 84 Euro Carrera |
Can someone confirm that in order to pull the lower valve covers with the 993 HE's that you must remove the HE's first?
Also can someone provide a link to the Wurth copper plated nuts with the 12mm head? Finally, can someone provide a link to the 12mm Snap On ratcheting wrench that has a flex head? Thanks for all the help. After my 3.2 project car is back on the road adding 993 HE's and a M&K muffler are one of the next mods. |
Twins are more fun!
Also, is this the Snap On, Flex-head, Ratcheting Wrench used for the 993 HE's? http://image.snapon.com/international/pdf/boermf712a_npa.pdf
James Carrera TT (3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's) |
Here's a link for you for the Wurth Copper plated nuts.
Link to Wurth catalog in pdf form http://www.wurthusa.com/project/media/new_online_catalog_2008/sections/HARDWARE.pdf These are the ones I used. Wurth Split Copper Exhaust Nuts (small Hex size) Wurth Part # 03662 specs: DIN 14440 M8 diameter 1.25 thread pitch M12 width across flats 8.5mm height There is also a flange nut style I did not use but is similar. It is noted for BMW use: Wurth part # 03658 same specs as above except 17mm flange 8.6mm height
No, you do not need to remove the HE's to get the valve covers off, but you will need to grind away part of the heater "inlet," which in its complete state will block the covers. You just need to leave enough meat on the exchangers to hold a hose clamp.
Twins are more fun!
I buy them from winzer for 8 cents each if that helps
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Metal Guru
If anyone wants to buy a Snap-On wrench PM me.....
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb Last edited by 911nut; 03-28-2009 at 05:41 AM.. |
What are y'all using for exhaust port gaskets with the 993 HE's?
Also - Ben - have you made any progress on making heat adapters to work with these heat exchangers? Thanks for the help guys, |
Twins are more fun!
I assume people are using the normal OEM Carrera Exhaust Port Gaskets as shown here:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_EXHpip_pg6.htm#item28 The 3.2 heads don't have the groove for the 964/993 exhaust port sealing rings, so I'll be using just the OEM 3.2 exhaust port gaskets as shown on that link above
I use the normal 3.2 Carrera exhaust port gaskets and regular 993 HE to muffler OEM Gaskets
