Where do you find these? (pic)
This is an engine that recently sold on the Pelican Used Parts forum. I really like the plug wire holders pictured that reach over the fan housing and bolt down with the bolts that hold down the shroud. Are these common to buy and I've just never seen them or are they difficult to source. Thanks everyone for your help.
http://forums.pelicanparts.com/uploa...1232852854.jpg |
I'm pretty sure those are the Beru plug wires. OEM equipment. Pelican has 'em.
The holders themselves are stock as well if that is what you are asking about....Pelican should have them as well.
They look a lot different in the PET
I have them on my engine. The part number on holder is 991.602.185.00 (Beru). They are 2 bolt holes on the fan housing that they bolt to.
i like the carbon fiber, I want one!!!
I'm either dense or I'm not a very good communicator
I think you meant 911.602.185.00. 991.602.185.00 came up blank. Would it be a big pain to have you post a picture of your engine from an angle that will help me understand? I'm thinking that those units you site, cab, are what I need for the other wires but I'm concentrating on the two units on top of the fan housing in this picture. I don't have photoshop so I can't really circle or point to the units I'm writing about. There aren't two bolts holding them on in the picture above. Nor is there a bracket for the metal screws to fasten into or some sort of metal plate on top of the holder itself. That's how the PET shows them looking and being attached anyway. Of course the PET is hand illustrated and not actual photos so I suppose it could look a lot different than the actual part. It appears that the ones I want use the same simple bolts that hold the fan shroud in place and only one bolt per unit. I'm pretty sure they aren't the part in the picture if the illustration in the PET means anything. Unfortunately, PP doesn't allow uploading PDF files or I could include the picture from the PET to this post. :( |
Rbuswell
Sorry for the confusion, the right part number is 911.602.185.00. My Mistake. There is actually one bolt holding each holder to the fan housing. I was refering to the fan housing, and that there are 2 bolt holes in it that holds both of the holders. Here is a close-up of the holder. Hope this helps you. http://forums.pelicanparts.com/uploa...1232928261.jpg |
Cab, that helps a ton!
The PET I have looks different than yours so mine is probably older and the illustration didn't match the part. Now I know what to buy! Thanks a ton.
I tried searching Pelican by various names and by part number and can't find these. Are they unlisted?
I have an extra set if you want to buy used ones. PM me for info
PM sent.
Yes I'm interested
| All times are GMT -8. The time now is 01:09 AM. |
