79sc Main Wire Harness Pinout Needed
Well the engine drop went well except for the fact that I pulled the cover off the main harness and all the pins dislodged from the plastic.
Does anyone know where to find a diagram for the connector. The plastic has numbered holes. Hopefully someone can give me a guide to wire color. this is the main harness with Thanks. Once AGAIN.
JOHN 79 EURO SC "24 Years Later - The Dream Came True" |
More info:
It's the 11 PIN Harness.
DISCLAIMER; this is my engine, yours may be different. I have various wiring diagrams around , PM me if you need more, I am in Langley.
That picture of the plug seems to use different numbers than the wiring diagram. My 80 SC engine has the following wires; T14: The big 14 pin plug at the left rear corner of the engine. Looking at the back of the plug, with the wires coming out the bottom, the numbering of the pins is from the top left (#1), then top right (#2), working down to the bottom right hand pin (#14). Here are the pin numbers, colours, and purpose of the wire, for my ‘80Sc 3.0: Pin # Colour Purpose 1. yellow starter solenoid 2. no wire connected 3. grn/blk oil temperature sensor 4. grn/red oil pressure sensor (for oil pressure indicator) 5. grn/yel Backup light switch 6. grey Backup light switch 7. no wire connected. 8. no wire connected 9. grn/wht oil pressure switch (for idiot light) 10. red/wht power for WUR, temperature valve, supplementary air valve 11. blu (x2) from” D+” terminals on regulator and generator 12. blk/vio from ignition box, to tach (tach signal) 13. yel/blk heater fan motor power 14. red generator output.
Rob 76 widebody project 86 Carrera Coupe 01 BMW X5 98 Jaguar XJ8 Last edited by avt007; 01-25-2009 at 09:24 PM.. |
As always.
Thank You!
