wannabee wannabee
3.2 low budget brake rotor / pad choices
any suggestions? so far it looks like 500 for set of ross drilled zimmermans or 300 for oem's. how bout pads? thanks in advance for any suggestions.
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
cross-drilled for Carreras is NOT recommended unless you want to replace them quickly. The rotors will show cracks from drill hole to hole. On the track, you could destroy a set of rotors in one day, so think about that. Normal OEM rotors are just fine.
Pads will depend on what you use the car for. Street and occasional DE, try the inexpensive MetalMasters. Better performing pads go up dramaticly. If you're going to do DE's then you want to get good pads. While you're doing rotors, remove the stone guard plate behind the rotor for better cooling especially if you do a DE, you want that exposure for cooling.
Tony G 2000 Boxster S |
wannabee wannabee
thanks!!!
wannabee wannabee
btw... what's DE?
At the track = great day
Driver Education.. basically an event where you and a bunch of like-minded enthusiasts drive your cars on a race track and learn the handling, braking and steering characteristics of the car better.
Lane 2011 Volkswagen Jetta SportWagen TDI Looking for another sports car.. |
wannabee wannabee
cool.. thanks! wish someday I could actually spend some time doing that.
NO to drilled Carrera rotors
Why? Her's why. This rotor cracked at speed on the track at MidOhio. Sounded and felt like someone hit the car with sledge hammer. Fortunately for me, nothing happened other than loosing the rest of the track weekend, but if the crack had been worse, it could have locked up that wheel (right front) as I was hard on the brakes for a fast left hander and could have spun big time. Only rotors that were designed to be drilled should have holes in them.
![]() ![]() In this pic, note the markings on the rotor underneath. Each area circled was another crack that was completely through the rotor. And this was after just 8 track days. I switched back to stock Zimmerman rotors and my pedal effort actually was slightly reduced and I had at least the same braking ability if not a bit more. And no brake fade with Motul 600.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
wannabee wannabee
OK thanks! I meant doing DE someday using plain rotors...
low budget rotors? How about this?
Fat butt 911, 1987 |
300hp 1800lbs is the goal
come on..... At least get the ones made in Canada.
![]() I don't know if there's any proof they're made here tho
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
What is the basic difference between the 2 types of rotors ? those shown before my reply. Magnum and the low budget ? thanks, Peter
84 911 Carrera SOLD not forgotten 01 911 C4 factory Aerokit ![]() 76 914 rust bucket SOLD !! 03 Boxster S sold 98 944 S2 G Red,sold 04 FRC red Vette |
wannabee wannabee
Thanks.. I saw those (yes I'm an eBay shopper) but unsure if they're a good buy compared to OEM's from Pelican. Don't want to be too cheap as I drive the car hard daily when given the chance. Do you agree?
