KBG KBG is offline
911sc window not staying in track
trying to get the drivers power window working correctly........the window goes up and down fine but won't stay in the rubber track that holds the bottom of the glass in......is there a rivet or something that holds it in there????
kind of hard to see
thanks in advance
Kevin
Old 01-27-2009, 10:23 AM
1980 911 SC
I beleive the glass is bonded to the rubber by adhesive. The rubber looked like it was pressed into the metal frame on the track. I had mine out a while ago and couldnt see any other method for securing the glass to the track. Its not that hard to pull the door panels.
Life's a Beach
Old 01-27-2009, 10:49 AM
muck-raker
kidrock's Avatar
I agree. Had the same issue with another type of vehicle recently. Use the adhesive sparingly, or it could get messy or become a bigger problem down the road if you ever need to repair the window frame.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 01-27-2009, 11:06 AM
Bill Douglas's Avatar
I used Urathane glue.
Old 01-27-2009, 11:08 AM
KBG KBG is offline
guess I will try that.....thanks guys
Old 01-27-2009, 11:31 AM
I used thinners to get the glass really clean so the urathane glue sticks. It's quite strong glue and not brittle - good luck
Old 01-27-2009, 11:56 AM
sikaflex 292.
206 637 4071
Old 01-27-2009, 12:11 PM
Nine9six's Avatar
Originally Posted by john walker's workshop View Post
sikaflex 292.
http://www.ellsworth.com/sikaflex.html?gclid=CNjUiOzRr5gCFRwpawod7GZ_UA
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 01-27-2009, 12:59 PM
