-   -   911sc window not staying in track (http://forums.pelicanparts.com/porsche-911-technical-forum/453782-911sc-window-not-staying-track.html)
KBG 01-27-2009 10:23 AM
trying to get the drivers power window working correctly........the window goes up and down fine but won't stay in the rubber track that holds the bottom of the glass in......is there a rivet or something that holds it in there????
kind of hard to see
thanks in advance
Kevin
sailchef 01-27-2009 10:49 AM
I beleive the glass is bonded to the rubber by adhesive. The rubber looked like it was pressed into the metal frame on the track. I had mine out a while ago and couldnt see any other method for securing the glass to the track. Its not that hard to pull the door panels.
kidrock 01-27-2009 11:06 AM
I agree. Had the same issue with another type of vehicle recently. Use the adhesive sparingly, or it could get messy or become a bigger problem down the road if you ever need to repair the window frame.
Bill Douglas 01-27-2009 11:08 AM
I used Urathane glue.
KBG 01-27-2009 11:31 AM
guess I will try that.....thanks guys
Bill Douglas 01-27-2009 11:56 AM
I used thinners to get the glass really clean so the urathane glue sticks. It's quite strong glue and not brittle - good luck :)
john walker's workshop 01-27-2009 12:11 PM
sikaflex 292.
Nine9six 01-27-2009 12:59 PM
Originally Posted by john walker's workshop (Post 4446684)
sikaflex 292.
http://www.ellsworth.com/sikaflex.html?gclid=CNjUiOzRr5gCFRwpawod7GZ_UA
