Stone guard removal and reinstallation
Can anyone post the process, tips, tricks for removing and replacing stone guards on a turbo?
Thanks in advance!
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
I used a heat gun to remove and was able to reinstall with no issues.
Take your time and remember to be careful with how close you get to the surface.
----------------------------- Ernie 81 SC |
Ernie,
Did you wet the back of the new stone guards after peeling off the backing, prior to installation? I heard that makes them more managable (able to move/adjust) during installation process, but would think it might negatively affect how well they stuck to the surface. Anyone?
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) Last edited by Nine9six; 05-23-2009 at 10:18 AM.. |
Designer King
There are some threads on this. You will find them via a search.
The pros mix up a really weak soap/water solution which they spray on the surface, and sometimes on the piece too, which they then slide into place. Then, as the solution dries, they quickly smooth out any air bubbles and wrinkles w/ a squeegee or burnisher. Teh solution does not adversely affect the adhesive.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
+1 very easy
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
