Post ? ? what engine are these cams for...901 105 109 04 / 901 105 110 04...Thanks!
NT
Old 06-02-2001, 07:08 PM
Early_S_Man's Avatar
Mark,
Per the '87 Stoddard catalog, those are Solex cams, used before the milder cams were incorporated for use with the tuned, equal-length '67 911S heat exchangers on the 'normal' 911 engine. They are the later production, non-cross-drilled version, for use with spray-bar lubrication.
Warren Hall
1973 911S Targa
Old 06-03-2001, 12:37 PM
Post
Thanks Warren, You have helped me again. Thanks!
So these are Solex cams, I'm building a 2.7 and I've read all of BA's cam recommendations, T vs E vs S top end, low end drivability around town etc. I have these Solex cams and a set of '73 S cams. Which cams will give me more performance. I know that they both will be dogs at low rpms, but they will work nicely at 4500 and above and that is were I drive.
The pistons I am using are 2.7 nikasil RS.
And the valves are 46 and 40mm.
Old 06-03-2001, 02:09 PM
