supercarrera82's Avatar
Blower in front hood not working on 79 sc, ne ideas
I have a 1979 porsche 911 sc targa and the blower is not working, the one located in the front hood in the little compartment in front of the gas tank. I use the controls inside the car underneath the dash on the center console but it doesnt turn on. Only thing that works is the front window defroster blower (whic are operated by different controls), any ideas? fuses are okay...any relays involved anything I should check, thanks much
Old 01-29-2009, 11:11 AM
muck-raker
kidrock's Avatar
Had a similar problem with my 88 recently...try disconnecting, cleaning and reconnecting the main power supply plug that snaps into the motor shroud. If that doesn't do it, you'll have to break out the voltmeter and start testing the plug and wires to confirm you are getting power to the unit.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 01-29-2009, 11:18 AM
COL 911
COL 911's Avatar
Front AC condensor blower
You also may consider inspecting the motor itself once you're certain the motor is getting the correct power. I took mine apart recently while doing battery maintenance and once I removed this wad of newspaper that had worked its way into the cage/fan, it worked fine again. No wonder the AC stopped working last fall - I guess I was lucky it hadn't burned the motor out by the time I found it.
Beetle, Bimmers, Saabs, and finally...1987 Carrera
Old 01-29-2009, 02:06 PM
Barrpete's Avatar
I don't have a wiring diagram handy, but I think that fan is connected through the relay in the smugglers box.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 01-29-2009, 02:20 PM
