-   -   Source for acid core solder for deck height measurement (http://forums.pelicanparts.com/porsche-911-technical-forum/454242-source-acid-core-solder-deck-height-measurement.html)
M491Cabriolet 01-29-2009 05:27 PM
I was wondering if anyone has a source for acid core solder to use to measure deck height in a 911 engine rebuild. I've only been able to find 1.6mm diameter solder. Any info would be greatly appreciated. Thanks.
peppy 01-29-2009 05:29 PM
Plumbing supply store.
RWebb 01-29-2009 05:33 PM
why can't rosin core be used?
M491Cabriolet 01-29-2009 05:49 PM
Just following directions. CE and Wayne talk about acid core solder nearly 3mm thick. I checked a big plumbing supply store today and all they had was solid solder. Any other ideas? Thanks.
DUK 01-29-2009 05:57 PM
why not use molding clay? Most hobby stores have it.
peppy 01-29-2009 06:05 PM
I can't put my hand on mine right now. I think I have some rosin core in the shop I could sent you a couple of inches if you need.
LM3929 01-30-2009 02:02 PM
send me your address I have a bunch of acid core.
Lorne M.
