daily driven 911
Split gas tank????
am i missing something here?? after leaving a big tar like gas smelling mess this morning i found this....
it's a good 10 inches long and atleast 3/4 of an inch deep.....
Old 07-21-2009, 08:14 PM
daily driven 911
Old 07-22-2009, 11:15 AM
dhrcr911s's Avatar
What did you run over??? I wouldn't think it would pull back like that otherwise..
SWB 911S 1967 307653S in my fathers garage now
LWB 911T 1971 9111120264 Back in my garage after a lenghty stay in Oregon
Old 07-22-2009, 11:33 AM
dtw dtw is offline
GAFB
Where is the fuel coming from? The pinch seam on the tank, or the fittings in the fuel pump area? You either have a failed fuel line connection (relatively easy fix) or your tank has failed (more involved fix), depending on the source.
Errrr not to be too opportunistic, but if you need a new tank I've got a couple nice ones.
Please be very careful - don't let the fuel vapors concentrate in your garage. When working down there, I like to pull the fuel pump relay and disconnect the battery. Can't be too careful when dealing with gasoline.
Several BMWs
Old 07-22-2009, 11:55 AM
daily driven 911
fuel pump and lines are dry, its either from that ridge/crack or the drain hole.
ARG!!! im still chasing a poor performance issue and now this.....
Old 07-22-2009, 02:03 PM
mca mca is offline
mca's Avatar
Hopefully the two are related and you can kill two birds with one stone!
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 07-22-2009, 02:06 PM
