changing spark plugs
i am changing the plugs on a 1977 911 targa 2.7 . For some reason i cant get the number one plug out, the socket will not go on to the plug, i am useing a 13/16 spark plug socket , i had no trouble at all and this one looks the easist to get to whats the deal anyone run into this problem before thanks
Old 02-01-2009, 11:08 AM
Max Sluiter
Flieger's Avatar
Use a metric socket for starters
Old 02-01-2009, 12:36 PM
Jupiter 911
bklyn's Avatar
Hey Pat, I also had a problem, it appeard the socket needed to bend to get in there. After racking my brain I went to the socket that came with the vehicle and low and behold it was flexable. Try that if you still have one in your kit.
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 02-01-2009, 01:00 PM
HarryD's Avatar
If you have your tool kit, the spark plug wrench Porsche included is the perfect tool for the job.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
you dont need a metric socket for starters and thanks guys for the help the socket was in the tool kit and it worked great
Old 02-01-2009, 01:10 PM
HarryD's Avatar
Patrick,
Glad to help. BTW... Welcome to what is probablly the best 911 Web Forum on Earth.
How about a picture of your car?
Harry
2020 MB E350 4Matic
Old 02-01-2009, 01:20 PM
+1, the oem tool is perfect. I did my engine last night with the oem tool with the allen wrench it comes with, along with a nice solid 12inch breaker bar that i would slide over the alan wrench to gain additional torque. Once they started to loosen up, i used a ratchet with the same sized hex bit into the oem tool. I did all the plugs in a little over an hour by removing nothing other than the airbox filter and cover.
1984 Porsche Carrera Cabriolet - sold, regrettably
2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably
2005 Mercedes C230 Kompressor Sport Sedan - now...
Old 02-01-2009, 03:13 PM
Carmagic.us
rothaus's Avatar
I don't have the original tools. I'm using a plug socket from the Metrench set, plus 2 short 3/8 extension. Insert the socket with one of the extension first, add the second extension and ratchet.
When the plug is loose remove the second extension, etc.
I hope this helps if someone doesn't have the original tools.
Cheers
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 02-01-2009, 05:08 PM
T77911S's Avatar
i put a swivel adapter on the the socket, then a short extention, perfect length.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-03-2009, 04:22 AM
(the shotguns)
berettafan's Avatar
i don't have a swivel on mine. it's an odd combination of craftsman extensions and it works perfect. can double check if anyone cares.
Old 02-03-2009, 04:38 AM
