Jupiter 911
Emblem adhesive ?
Gents, I purchased a new Carrera emblem for my engine lid from our host. The one for my 87 Targa did not advised if it was self adhesive or not. When I receive it and it is not self adhesive, what type of adhesive would you recommend? Thanks Lenny.
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
Friend of Warren
You need to go to an auto parts store and get some 3M double sided tape.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Jupiter 911
Kurt, but that would mean a lot of cutting around the script, I am not that steady.
a.k.a. G-man
I believe it would envolve some cutting, yes.
Shouldn't be that hard though.
Сидеть, ложь, Переворачиваться |
Jupiter 911
Do you think it would be better then the yellow or black 3m adhesive in a tube?
cycling has-been
I've had good luck with a clear silicon sealant.
Doesn't damage the paint and you can wipe off any excess with a couple of toothpicks while it is setting up (recommend 24 hours). Leave the lid open and let gravity do its thing while it is setting up. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Jupiter 911
Bill, that sounds like a good idea, I believe the clear would do a better job. Thanks guys but I am still hopeful the emblem is self adhesive!
Get GE silicon 2 for outdoor uses. They are excellent silicon.
Pre Registered
Designer King
If the emblem isn't self adhesive (and I think it is) you can apply the SA material to the back, keep a backer sheet behind it, and use the edge of the emblem itself as a guide to run a sharp X-Acto type knife around it.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Jupiter 911
Thanks guys, like I mentioned I hope it is self adhesive but when I ordered it, for my year, it did not say in any of the notes or description but either way I work with it. I got some good ideas from all. Lenny
