B D B D is offline
B D's Avatar
Plating Weber Carb Parts
I've taking some stuff to the platers and was wondering if I can plate my Weber carb parts. Obviously I can do all the linkages, springs, and nuts but what about jets, screws, tubes, plugs etc?
Should everything be yellow/gold cad?
68 911L
Old 02-03-2009, 01:19 PM
You can ask Bieker what they normally send out during a rebuild. The short answer is yes, it should be gold. I also believe all of the cross linkage should be same. He can give you a list of the parts he normally sends out.
Matt
72 911T Targa - Sold
Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat.
Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!!
Old 02-03-2009, 01:40 PM
(the shotguns)
berettafan's Avatar
i wouldn't do ANY of the brass stuff.
Old 02-03-2009, 01:50 PM
B D B D is offline
B D's Avatar
It seem Bieker puts gold zinc on everything even the brass parts.
68 911L
Old 02-03-2009, 11:33 PM
andrew15's Avatar
No to the jets and emulsion tubes - these have very precise machinings and flow patterns - you don't want to mess them up. As for the jet holders and float bowl plugs, why not polish them?
The steel parts like the air adjuster and idle screw are fine to be plated.
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 02-04-2009, 04:06 AM
