-   -   915 Asymmetrical upgrade question (http://forums.pelicanparts.com/porsche-911-technical-forum/455565-915-asymmetrical-upgrade-question.html)
Fest 911 02-05-2009 02:53 PM
Hello all,
I've been reading so many 915 rebuild posts that my eyes are starting to bug out! My 915 is out of a '74 911 that sees a lot of autocross use for now and will eventually enjoy some track time.
Among other things, I am planning on doing the 1st gear Asymmetrical Hub Update. Is there a similar update for the other sliders/hubs that would be worthwhile?
Thanks for any and all advice!
Matt
Grady Clay 02-05-2009 05:55 PM
Matt,
Welcome to the Forum
You will find a lot of help here.
No, the asymmetrical engagement teeth are for 1st gear only.
There is an improver hub and sliding sleeve for the 3-4 gears that is stronger.
As you prepare for your rebuilt, collect all the posts and published manuals. You will need to make or borrow a few special tools. It is useful to find a junk (not rebuildable) 915 to practice on.
Best,
Grady
Fest 911 02-05-2009 06:02 PM
Grady, Thanks for the info. It appears that the asymmetrical upgrade parts are just the stock parts for '77-'86.
For the improver hub and sliding sleeve for the 3-4 gears, do you know if it's the same deal (the stock parts for '77-'86) or is it an improved part for the early box? Does that make sense?
Thanks for your assistance,
Matt
Grady Clay 02-05-2009 06:16 PM
...is it an improved part for the early box?
Matt
Yes to both.
Best,
Grady
