Need help finding Distributor washers
Any leads on how I can replace the little washers that the advance weights ride on? Both of mine were split and need replacing. Is this a critical component? I went to NAPA and they had a rebuild kit for the HEI dizzy and it had a teflon bushing with something on the bottom to ride on.
McMaster-Carr. http://www.mcmaster.com/
Order the stainless steel shims they are high heat resistant. You just need to match the ID or dremel for a snug fit. The most important and impossible one to replace is the inner snap in bearing made of poly-blend. Ask me how I know. |
| All times are GMT -8. The time now is 05:03 PM. |
