Old 60's Porsche Tech
captainlewis's Avatar
fuel pump feed hose id from tank to pump??
85 carrera what is the fuel supply hose ID that goes from the tank to the fuel pump, thanks JL
Old 02-07-2009, 03:42 PM
11.8 mm ID x 17. 8 mm OD; Porsche part no. 999.181.168.50
Old 02-07-2009, 04:11 PM
burgermeister's Avatar
1/2" fuel line from the auto parts store works quite well also. 7/16 is a bit too tight to fit.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-08-2009, 07:12 AM
I seem to remember that my stock tank to pump hose had a tough outer covering unlike the hose available now? Maybe I just can't see it?
pic is from PP
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-08-2009, 04:08 PM
3rd_gear_Ted's Avatar
Once you drain your gas tank, you should consider installing a filter between the tank & pump. Why Porsche didn't do this on the 911 is a wonder?
1980 911 - Metzger 3.6L
2016 Cayman S
Old 02-08-2009, 04:14 PM
This is what Porsche sent (via Pelican Parts).
Old 02-08-2009, 04:27 PM
