-   -   Heated windshield in SC? (http://forums.pelicanparts.com/porsche-911-technical-forum/455943-heated-windshield-sc.html)
sbmackie 02-07-2009 04:40 PM
Hello,
The paintshop guru said my windshield had heater elements in it, small wires, etc.
I don't see any switches for windshield heat. Was ist?
sbm
tdatk 02-07-2009 05:26 PM
You do indeed have a heated windshield. You need to pull out the defroster knob located above the radio to activate it, if it is in fact hooked up.
Flat6pac 02-07-2009 05:27 PM
I had a 77 with the heated windshield and as I recall it worked with the defogger which heats the rear window and the outside mirrors
Bruce
porschenut 02-07-2009 05:53 PM
Are you sure the wires aren't actually the embedded radio antenna?
spuggy 02-07-2009 09:33 PM
Uhmm. Interested, I plan to replace my 250,000 mile screen with a heated one...
I think the Carrera pull-out defroster knob twisted to activate the front screen heat, didn't know it was an option for a '77...
DRACO A5OG 02-07-2009 10:29 PM
Strange will check my owner's manual. I don't recall this feature?
Pazuzu 02-07-2009 10:34 PM
From the Red Book, option M443, heated front and rear windows and tinted windows was available from 74 on.
tdatk 02-08-2009 07:00 AM
It's hard to see, but If you look at the bottom 1/3 of your windshield on a flat plane in the sunlight, you will see the very small wires across the length if you have the option.
dentist90 02-22-2009 03:20 PM
I've got the heated front windshield as well. This year I have to re- and re- my windshield to get at a rust problem. I seriously want to avoid damaging the glass and the little wire connectors. Before I start cutting out the windshield gasket and pushing out the glass, does anyone know which side the defroster wires are connected?
