-   -   Fiberglassing how-to instructions? (http://forums.pelicanparts.com/porsche-911-technical-forum/455949-fiberglassing-how-instructions.html)
JohnJL 02-09-2009 01:59 AM
Here you go Paul, up close and then from further back. You dont even see them unless you look for them. Please ignore the wiring, I'll wrap that up soon....
http://forums.pelicanparts.com/uploa...1234173360.jpg
http://forums.pelicanparts.com/uploa...1234173387.jpg
http://forums.pelicanparts.com/uploa...1234173403.jpg
JH, thats funny, here's the old shroud from when I had the old cooler on there...
http://forums.pelicanparts.com/uploa...1234173446.jpg
Kroggers 02-09-2009 02:29 AM
Cool, thank you John. I will do the same (will see if i can get some cheap ones on e-bay)...
Ove 02-09-2009 02:30 AM
[QUOTE=JohnJL;4473957]Thanks Ove, I just saw that with Paul's direction. How is the flow from that? QUOTE]
The flow is very good when the car is moving. It (obviously) increases with increasing speed. The inlet hole is small, but all I need. No filters etc to restrict the air.
I was going to make the inlet from fiberglass, but this was easier to make as I aready had the aluminum parts. Since it works so well I will keep it as it is.
Remember that water will get into the system when it's raining. I just made a small hole in the hose that connects the inlet to the air vents in the dashboard. Water runs down into the smuggler's compartment and out of a hole down there.
Nice hair dryer set up! Maybe something I'll try myself to speed up the defrost :)
http://forums.pelicanparts.com/uploa...1234175303.jpg
JohnJL 02-21-2009 10:13 PM
Project abandoned after seeing how twisted and poor the airflow would be after going around the wiper arms.
I'll go see if I can find the old vent and bastardize that.
