Oil level sender testing (out of tank)
When I removed my sender unit I found it tangled into a dipstick (quite common from what I've read). So now I wonder if the high pegged level needle was linked to a faulty unit or due to the tangled dipstick. Any easy was of testing or should I just replace it (after 23 years of use) ?
Champaign and Burgundy 3.2 (1986)
Ex-C4 91
Ex C4 93
A8 3.0 TDI
X5
Old 02-08-2009, 01:23 AM
I just replaced mine a few years ago instead of trying to fix the readings,
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-08-2009, 05:37 AM
with a couple of jumper wires, connect the ground and signal wires in the fender to the sender, turn on the ignition and move the sender up and down as you watch the gauge.
206 637 4071
Old 02-08-2009, 07:27 AM
crustychief's Avatar
I replaced mine two weeks ago. if the level is pegged then you have an open somewhere, my guess is in the windings of the sending unit. These things live / work in a pretty harsh environment with the heat and vibration. Notice the winding where it was chewed through by the float arm.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 02-08-2009, 08:10 AM
