head to cylinder sealing ring
on a 2.7 cis is it possible to install the sealing ring upside down one side is flat and the other is kinda sharp i imagine one end gets crushed down. any knowhow on this matter thanks.
Old 02-09-2009, 10:32 AM
I think your question will be answered better in the engine rebuilding forum (as I assume you are either doing a top end rebuild or something similar).
There is no sealing ring between the cylinders and the heads. You use loctite 574 (or similar) anerobic sealing compound.
Buy Wayne's rebuilding book. I bet it'll answer this question and many more you don't know you have yet.
Old 02-09-2009, 11:17 AM
EBS_Don's Avatar
Hi,
There has never been anything published that dictates a proper up or down for these head gaskets but I know what you are talking about. If you put the "sharp" end down in the groove the "flat" side will cover the gap better. I think Rick is referring to the head to cam tower sealing as you would never use a sealant between the heads and cylinders.
Don
Don Weaver-EBS Racing
don@ebsracing.com
2006 Cayman S
'86 944T
'00 Boxster with EBS Racing 3.4 liter engine
Old 02-09-2009, 11:35 AM
Thanks Don. You correctly assumed what I was referring to and offered the right answer. I blame my coffee for not doing it's proper job this morning.
Old 02-09-2009, 11:38 AM
right on thanks
Old 02-09-2009, 11:43 AM
there is absolutly a sealing ring between cylinders and heads...no loctite here!...must have been a mistake lol
Old 02-09-2009, 03:06 PM
