-   -   machining question (http://forums.pelicanparts.com/porsche-911-technical-forum/456348-machining-question.html)
Iowa911 02-09-2009 02:22 PM
machining question
This is actually for my 912, I am doing a free-flow conversion like the one described on this link. What method would you use to block the oil galley (labeled "C") . Sorry for the 912 content, but you guys have always come through for me on the 911.
http://www.356registry.org/tech/full_flow_oil_filter_systems.html
David 02-09-2009 02:42 PM
Can you get to the open end of 'C' and drill and tap for a plug?
Iowa911 02-09-2009 02:46 PM
I was thinking either that or machine a plug slightly oversized and heat the cover to create an interference fit. Any thoughts on which would be better?
Nine9six 02-09-2009 05:27 PM
The method of plugging would depend on if you ever needed to open, or gain access to "C" again.
If so. Drill, pipe tap, and pipe plug.
If not, insert a plug of the correct material and weld closed
cgarr 02-09-2009 06:14 PM
This one is testing my memory, I did my 912 engine about 6 years ago. I used a threaded piece of alum and threaded it into the oil pump outlet passage and ground it smooth within the pump gear area, never to be removed. I cracked my case taping the outlet so be careful, ended up welding in the outlet fitting in the third case part, work just fine. I used the Canton oil filter. This is a great upgrade, it filters your oil just before it hits the mains.
Iowa911 02-09-2009 06:18 PM
Tell me about the canton oil filter, I'm not familiar with that name.
cgarr 02-09-2009 06:32 PM
Here is the original setup with the HP-1 filter which I never used, I set it up so the filter mounted to the back of the engine, it was replaced with the canton (blue filter) with replaceable cartridges.
http://forums.pelicanparts.com/uploads/eng6.jpg
http://forums.pelicanparts.com/uploads/today1.jpg
http://forums.pelicanparts.com/uploads/100_0019.jpg
Here is their filters: http://www.cmfilters.com/spin-on.cfm
Iowa911 02-09-2009 06:44 PM
I was planning to mount my oil filter in the left rear wheel well. I've never seen one mounted like yours. Is there an advantage to doing this way?
cgarr 02-09-2009 06:58 PM
Its just makes a nice neat, clean setup plus there is no pressure drop through the long lines. Remember this is the oil that needs to go direct to your crank: Shorter the better. Canton also has remote filter setups too:
