schmidter91's Avatar
Car won't start...
1982 Porsche 911SC
74,000 miles
After about an hour of driving, I fuel up and when I go to start the car: nothing. All the instruments come to life, the fuel pump buzzes, and lights go on, but the starter won't click or engage. I tried starting it for about thirty minutes, and even attempted to push start her, but that did not work either.
I have experienced this problem before, but the car always starts within a minute or two.
Ideas?
Ryan Schmidt
1982 Porsche 911SC Coupe
Old 02-12-2009, 05:32 PM
check the solenoid connection on the starter. it may be pretty corroded. Somewhere in the starter loop there is probably an intermittent connection. Check the ground connections on the intake runner, and the ground strap to the transmission, , and the alternator connections (unlikely). Aternatively if you do a search im sure there are a million threads like this. Think about it, 25+ years the 911 has been on the road, im sure that whatever is happening to you has already happened to plenty of other people and it is most likely documented.
1984 Porsche Carrera Cabriolet - sold, regrettably
2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably
2005 Mercedes C230 Kompressor Sport Sedan - now...
Old 02-12-2009, 06:41 PM
Nice marmot.
mike_dunn's Avatar
Same thing happens to me sometimes. I have to whack the starter solenoid with a hammer. I've yet to replace the starter so I carry a hammer in the toolkit.
Old 02-12-2009, 07:24 PM
starter is suspect
Since the starter doesn't turn over "not even a click", one would just get a rebuilt starter and swap the old one out. However, the fact that you can't get the car to be jump started is contrary to just having starter solenoid issues. Starting occurs when there is spark and fuel appropriately metered out. Your CIS system may be gummed up by the ethanol based fuels today or rusty from the corrosion in the lines and fuel distributor. Also one should check for proper fuel delivery and fuel pressure by removing the air filter and reaching inside the airbox and lift the lever under the plate (3" diameter plate which has an adjustment for the resting gap.)
Hopefully you would have updated your air-box with the toilet bowl pop off valve to protect against blowing up the airbox due to backfire from incorrect fuel air mixture/timing.
Old 02-12-2009, 08:03 PM
Could be all the teeth on the starter are finally grinded...
Old 02-12-2009, 08:06 PM
Wer bremst verliert
JohnJL's Avatar
You'd hear the starter spin if that was the case.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 02-12-2009, 10:43 PM
Thanks for the help guys.
I went back to retrieve that car four hours later, armed with a trailer, she started right up. One odd thing was that the memory functions on the radio were reset.
Could this be a bad battery? I suppose tracing electrical connections will be next.
Ryan Schmidt
Old 02-13-2009, 11:23 AM
I had a similar problem on my 83sc last year. It would start on occassion and then other times just wouldn't. The one difference I had from you is that I could always get it to start via push start. Using jumper cables didn't help the problem very often. After I replaced the ground strap, battery, and removed my alarm thinking it might be draining the battery, it turned out to be a faulty solenoid on the starter. Replaced the starter and it has started up every time since then.
Mattlock18
1983 Porsche 911SC (Katarina)
Old 02-13-2009, 01:08 PM
