-   -   correct rev limiting rotor (http://forums.pelicanparts.com/porsche-911-technical-forum/456609-correct-rev-limiting-rotor.html)
356robo 02-10-2009 06:56 PM
My 2.2 T engine has been modified with:
Original T crank
S pistons & cylinders
mildly ported T heads
E cam
What would be a suitable rev limiting rotor? 6800, 7000, or what?
Thanks in advance,
Robo
timc 02-10-2009 07:50 PM
I used to have a 2.4T with E cams, and I used a rev limiter rotor from a 914-4, as it came in right a 6k, (which is funny, because the 914 redlined at 5.5K)and left no risk of any possible engine damage, and the car pulled strong right up to 6k.
You have a non counter weighted crank, and I assume you are still using stock valve springs? If so, I don't think I'd use the 7k limiter,With the 2.2 crank and springs.
