Just bought M&K 2in 2out and SSI's
I just bought M&K 2in 2out and SSI's. What amount of HP will this add to my 79 3.0 911SC? Just looking for a range not exact. If there are Dyno results then great.
Thanks. |
(the shotguns)
dunno about hp but if the MK sounds anything like my homemade 2out you need to go find a tunnel to drive through as soon as you get it installed.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
I've never seen anyone post anything about power on MK mufflers. I've asked the question, but no data has been brought forth. My guess is there are better options for power in the muffler category, but it's hard to argue the price and the fact they bolt right up.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Go to www.911chips.com and read through the dyno data. You should get close.
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Turgid Member
I put the same setup on my 87 3.2 Carrera (I also added a Wong chip) and the first thing I noticed when I started up the car was the throttle response. Much, much better. I don't know about actual power, but the engine "woke up" and was much livlier. The second thing you'll notice (actually, it will be the FIRST thing!) is the sound. Orgasmic is an understatement. You can listen to all the sound clips you want, but until you hear and feel your new exhaust you just don't know what you're in for. Expect your first test drive to be 1 hour+. Also, expect to tweak your idle and mixture settings slightly. I can tell you how to do it on an '87, but I'm not sure on a '79.
Good luck and post your first impressions!
'87 Carrera "Man who go through airport turnstile sideways going to Bangkok" |
user & abuser
there should be a noticeable gain... SSI's are a nice improvement, as is the M&K muffler... both flow much free-er... i don't think we are talking 10+hp, but i'm sure its gotta be close to 10hp....
79 sc has...180 stock? say 5% gain and its 189, but I think that is flywheel-hp..now wheel...so factor in some loss (15%?) and you got 165ish.... but then again how old is the engine? how many km's? sounds will be very very nice.
vini vidi vici |
In my opinion, the vast majority of the power gain comes from the SSIs, not the muffler. With that said, here are some performance results from a few years back with SSI's and a Dansk.
Performance Test done - SSI vs Stock SC
1979 Porsche 911SC Targa 1996 Porsche 993 C4S 2005 Porsche 996 Turbo S 2020 BMW X3M Competition 2003 BMW M5 |
THanks
Carl F 2000 Ruby Red Dodge Stratus with high performance racing stripe SE edition WTF? (sadly gone, but not forgotten) 1997 HOnda Accord "Shaggin Wagon" 1987 All black Targa 1998 Lemond Zurich/Dura Ace 2005 Jamis Dakar Sport 2006 Lemond Reno 2 DOgs , 2 Cats, Shi@ton of fleas 1 Cool as Hell Wife that tolerates my stupidity |
Turgid Member
http://www.911chips.com/dmeconvr.htm Good luck!
thanks for the link. I will be getting a wong as soon as I get one of my apartments rented out. Thanks
